Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 02-01-2004, 07:26 AM
gwsallen gwsallen is offline
Cefiro chamber and alignment troubleshoot.
Hi All,
I am facing problem with my chamber and alignment for rear wheels. Lately, I’ve changed to HKS Hyper Damper absorbers and of course my car is lower comparing to stock absorbers.
I want my car to be low and at the same time I want my chamber to be about –0.5 degree. I did alignment and chamber after fitting in the HKS absorbers, but the workshop fellow told me he tried everything to get –0.5 degree, but unsuccessful. The reading now is about –3.0 degree on both sides. I have the toe alignment problem on the left rear but not the right one. Any GURU here can advice me what to do? Any replacement kit for the bolts and nuts? The workshop recommended me to change the whole lower arm kit to RB25 4WD. Does it fit?
Thanks in advance.
Old 08-14-2004, 07:09 PM
zephyro zephyro is offline
Send a message via Yahoo to zephyro
Re: Cefiro chamber and alignment troubleshoot.
you should get the rear adj. camber link/arm/rod/kit together with the rear adj toe link/arm/rod/kit and rear traction link/arm/rod/kit. so that you can dial-in the numbers u need. you can use the S-13,silvia, or S14 aftermarkets.
