Old 02-01-2004, 12:12 AM
MrCrazy's Avatar
MrCrazy MrCrazy is offline
blow up my tech
does anyone know if i put turbo on my 95 ex tech could it run succesfully without internal upgrades. iam planning on running 20psi? i want to know because i will have to be running it with no internals for a while. Should i wait till i get internals first to be safe?
if you could tell iam new when it comes to turbos.
thanks
Old 02-01-2004, 12:53 AM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
I've heard of people running 10psi with stock internals, intercooler, bigger injectors, air fuel controller, and a lot of quality tuning. You should just save up more $ and go with internals or just do a B-series swap. With the D16 you've got now; with a good turbo kit and motor work will do a lot more hp with a turbo running 20psi of boost than just a N/A B16a or GS-R... but it takes a lot of time and $ to do it and do it right and not have the motor blow with a turbo running that much boost. Not to mention running more than 14psi (i believe) your ecu will need it's fuel map upgraded.
Old 02-01-2004, 01:28 PM
Miataracer's Avatar
Miataracer Miataracer is offline
Send a message via AIM to Miataracer Send a message via Yahoo to Miataracer
your "tech" will go boom on 20 psi with stock internals
LS1 RX-7 Zoom Zoom
Old 02-01-2004, 08:25 PM
quick95civic quick95civic is offline
hey, I think I might be able to help you here. Im currently running a turbonetics T3/T4 hybrid turbo on a d16z6 in a 95 honda civic. I am running 5 psi and it makes an enourmous difference in the power of the engine. If you go turbo you can expect to run close to 8 psi on a daily driver with out needing to modify the internals. I tried running 10 psi one time just to see what it would do and on the street there isnt enough traction to make the power useful, so it isnt really worth it.
Old 02-02-2004, 09:55 AM
Ricochet's Avatar
Ricochet Ricochet is offline
Banned
Re: blow up my tech
Go ahead and push 20 psi on your stock engine if you want to shoot down some airplanes with your rods.. btw wtf is a 95 ex tech?
Old 02-02-2004, 10:57 AM
Miataracer's Avatar
Re: Re: blow up my tech
then when he is done sending rods into orbit he can buy my old d16z!! LOL
LS1 RX-7 Zoom Zoom
