Old 02-01-2004, 12:28 AM
dapolice1 dapolice1 is offline
1992 v-6 manual to LS1 and 4l60e
I have done many swaps before and already have the engine and trans from a 2002 Camaro.
I have ordered Street and performance's wiring harness and accessories for the vette application (locates the alternator and A/c higher on the pass side to avoid frame interference).
I already have their billet mount adapters that allow you to use the regular 3 bolt style older chevy mounts. It also moves the mounts to the location of the old style mounts on the ls1 block so that the dimensions are the same.
I am going to upgrade the dash to the 1998 unit and gauges. My question is since the LS1 and 4l60e have a stand alone comuter can the factory truck ecm, drak, and other stuff be removed from the truck?
Are there any basic body functions such as the sensors from the engine? I think I will need to use the v6 or the 350 stock sensors in the LS1 block so that the gauges will work. I am just not sure what all the factory truck MUST run after the instalation.
396ci 500hp 6.5L LS1 Crate Engine on Ebay B3Enterprise Engineering/ Technical 2 11-05-2004 06:07 PM
396ci 500hp 6.5L LS1 Crate Engine on Ebay B3Enterprise Engineering/ Technical 2 09-13-2004 11:41 PM
396ci 500hp 6.5L LS1 Crate Engine on Ebay B3Enterprise Engineering/ Technical 2 09-13-2004 05:19 PM
396ci 500hp 6.5L LS1 Crate Engine on Ebay B3Enterprise Engineering/ Technical 0 09-13-2004 01:48 AM
Automatic LS1 VS. Manual LS1 1/4 mile _99_Formula Camaro Discussions 9 12-05-2003 02:15 AM
