Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 01-31-2004, 11:10 PM
bumsinflt bumsinflt is offline
Angry 99 Intermitted defroster fan
Intermitted Defroster Fan - Any ideas usually at startup - sooooo cold - ready need to get it working - any work arounds - or something operationally I can do so it works. Thanks
Old 02-01-2004, 10:33 AM
markwb's Avatar
markwb markwb is offline
Re: 99 Intermitted defroster fan
Tom,
Does the car have auto climate control? If car has the manual HVAC system, it may just be a resistor pack that needs replacement, or loose leads..... something to that effect.
Mark
2003 Pontiac Bonneville SSEi, 1999 Ford Escort SE, 5 Speed
IBEW Local 261 Groton, CT
Old 02-05-2004, 11:36 AM
radeohedca radeohedca is offline
Bad heater blower
I had the same symptoms with my '96 Bonny.
Read the thread under the subject of: "Tech question..Climate controller..how does it work ?"
Cheers, Hugh
Old 02-07-2004, 09:46 AM
Re: Bad heater blower
Cheers, Hugh
Hugh - Thanks for help but where do I find Tech Questions? I went to articles but only 9 were listed & climate controller was not one of them.
I'm new to this web site and I'm trying to help some one whose husband just died to sort out a intermitted defroster - she is afraid that a repair place will cost too much - it's cold here and she needs info. Thanks
Old 02-09-2004, 07:07 AM
Re: Re: Bad heater blower
The referred thread is currently 10 or 12 subjects down from this one in this Bonneville forum. In a nutshell, I replaced my intermittent blower assembly and it fixed the problem. It is located in the engine compartment, just a little to the drivers side from the center of the firewall. I had to remove the shocktower crossbrace and a steel bracket that were in the way of allowing me to get the blower assembly out. There's a small bypass tube on the bottom of the blower assembly that you have to carefully remove as well as the power plug. There are about 5 or 6 small hex screws that hold the blower assembly onto the firewall. Once I removed them I was able to fanagle it out and get the new one in.
This is all assuming that the "defroster fan" you are talking about is the heater and A/C blower.
Hugh
heater/defrost fan with intermittent speed 1986tercelowner Tercel 1 11-07-2005 09:56 PM
defroster fan problem Rose Harmon Cutlass Series 2 03-14-2005 07:12 AM
Defroster/fan Failure trishcavalcante Malibu 6 12-06-2004 07:49 AM
99 oldsmobile 88 - defroster fan is intermittented and car stalls when going slow bumsinflt Eighty Eight 1 09-07-2004 10:57 PM
99 Intermitted Defroster Fan bumsinflt LeSabre 0 02-01-2004 09:19 AM
