Old 01-31-2004, 10:51 PM
H.tech H.tech is offline
Send a message via MSN to H.tech
98 civic rear wheel drive
Hey guys i was just pondering on this thought of putting a CRV drive train on to my b18c block and making it rear wheel drive now i know its lots of work but i was wondering if anyone has done this on a 6th gen civic if so please give me a little info on mounting the drive shaft, rear diff , axels and struts
Old 01-31-2004, 11:33 PM
IntegraB18LS's Avatar
IntegraB18LS IntegraB18LS is offline
Just to throw an idea out because you would have to go autmoatic if you went that way (CRV tranny)
I used to have a 1988 Ford Escort GT, then i blew the clutch in it and it has 190k on her. I should of did this but I didnt, I also had a 1990 SHO with the body rotting off. What I was going to do (Yeah Im a hack) was cut a huge hole in the back of the escort and then cut off the front clip of the SHO. I was going to them cut out everything but pretty much the shock towers, cradle, engine, tranny... ect.. then take that whole assembably and weld it in to the esort (put the engine and stuff in from undernieth) I was going to mount the SHO gas tank in the front and take the SHO dash and wiring harness and mount it in the escort (cut it if need be) but then everything would be there and it should start right up, you would have to build a firewall over the engine but damn it would be a mid engined RWD car. obviously what I was going to do would of been the very hacked way and probably would keep breaking shit, but if you think about it it is very easy if you have a toruch and a welder, if your good at fabricating you could make it look nice besides who needs a back seat?
Oh yea if your wondering why I didnt do it is because I wanted to find a automatic SHO because they have 3.2's and would be much easier to make linkage for an auto tranny then a rod shift manual shift tranny, of course the more i think about it as long as ground clarance isnt that much of an issue it would be fairly simple to make that.
Well anyways I think that would be more interesting but you have to be a good fabriacater because you wouldnt want to ruin a good civic, but hell while your at it make it twin engined
If you do use CRV running gear you might as well make it AWD, it wouldnt take to much more work. there was an artical in some magazine i read about a while ago
lol anyways good luck
Kyle
[url=http://www.automotiveforums.com/vbulletin/showthread.php?
1995 Honda Civic EX
-Integra B18B1 LS engine
-Turbocharged
-Rear disk conversion
-Many mods
Cheak out my civic (cardomain)
Easly got 10k into this car with everything and it still looks like a POS
Old 02-01-2004, 03:23 PM
BullShifter's Avatar
Re: 98 civic rear wheel drive
If I were to do something like that, I would use S2k drivetrain or NSX & have the engine in the back.
Old 02-01-2004, 03:51 PM
Re: Re: 98 civic rear wheel drive
If you used like a S2k drivetrain I bet you would run into lots of problems such as the tranny hitting the steering rack and stuff like that. NSX engine in the back would be fun
you can do anything you want as long as you have money
1995 Honda Civic EX
-Turbocharged
-Many mods
Old 02-03-2004, 04:07 PM
pasha's Avatar
pasha pasha is offline
a local guy hopes to drop a 350 into a hatch.. not sure how that is going to work out..
anyways, if you want rwd, get a diferent car.
Need webdesign? I can help ==> 2design.da.ru
89or90 2600i 4x4 rear wheel bearings B4 roadtrip discretegeek B-Series/Bravo/Bounty/Drifter 0 03-29-2010 08:38 AM
89or90 2600i 4x4 rear wheel bearings B4 roadtrip discretegeek B-Series/Bravo/Bounty/Drifter 0 03-29-2010 08:37 AM
What is better front wheel drive or rear wheel drive? auto600 Engineering/ Technical 1 05-03-2007 11:31 AM
Rear Wheel Drive Or Front Wheel Drive? Cereal_Killer Avenger 1 06-22-2005 10:00 PM
