Go Back   Automotive Forums .com Car Chat > Chevrolet > S-10
Old 01-31-2004, 09:46 PM   #1
angelsairman
heater only works in 2 positions!! HELP!!
Here i am in North Dakota in the middle of winter and today my heater starts acting up. 1998 S10 4.3 w/AC For a while now it wouldnt switch over to floor and starting today it will only blow air in the 2 or 3 positon. What could this be??? The chiltons manual was far from even coming close to being any help, not even a breakdown of the system. Can someone throw out some ideas and maybe some referance materials!!! Thanks
angelsairman is offline   Reply With Quote
Old 03-01-2004, 07:33 PM   #2
gerryff
blower switch doesn't work in 4 position
Hey Bud, I have the same problem only my fan works in the 1, 2 and 3 position but not in the 4 position. I have changed both the switch and the blower motor resistor but neither solved the problem. Any ideas what else it might be?
gerryff is offline   Reply With Quote
Old 12-15-2004, 02:53 AM   #3
Inze
Re: heater only works in 2 positions!! HELP!!
I have the same problem with my 96 s-10 blazer my blower motor only works in the 1,2,3 position no high. I replaced the blower motor and this didn't fix it so I took it back out and returned it, then I replaced the dash board blower switch and this didn't fix it so I also returned that, then I replaced the blower resistor relay under the hood on the fire wall next to 2 other relays and this worked, unfortunatley temporarily until it blew again. SO something else is causing the problem. I heard it could be a bad motor or a bad ground but I don't know? I was going to bring it to the dealership this coming monday but I would rather not @ 83$ per hour! Now when I replaced the blower relay under the hood and I accelerated pedal to the metal my interior lights came on and flickered?? SO I guess it's something like a bad ground also when this relay blows it really blows and melts! I SURE HOPE SOMEONE HAS SOME HELP ON THIS. I have been searching this site and with most electrical problems there is no soulution given....
Inze is offline   Reply With Quote
Old 12-15-2004, 09:18 AM   #4
xtremetrk
I have a 99 S-10 4-banger and when im stopped 3&4 work but when i have it on 1or2 while im driving it will work because the air from driving forces to blower to move.
xtremetrk is offline   Reply With Quote
Old 12-15-2004, 03:54 PM   #5
dmbrisket 51
dmbrisket 51's Avatar
Send a message via AIM to dmbrisket 51
1 2 and 3 go through a relay and 4 is wide open
dmbrisket 51 is offline   Reply With Quote
Old 12-15-2004, 04:30 PM   #6
BlazerLT
AF -Advisor
BlazerLT's Avatar
for the positions, check for a vacuum leak from the heater controls and valves.
For the fan speeds, 1,2,3 go througha resistor, full power goes through I believe a separate relay.
1995 Factory Blazer Service Manual for sale, PM if interested.
BlazerLT is offline   Reply With Quote
Old 12-16-2004, 02:00 PM   #7
xtremetrk
Where are the relay's and resistors located?
Old 12-16-2004, 03:28 PM   #8
BlazerLT
AF -Advisor
BlazerLT's Avatar
The fuse box in the engine bay if memory serves me correctly.
Old 12-16-2004, 10:54 PM   #9
Mikado14
The resistors should be located in the heater box so that the blower will cool them.
Mikado14 is offline   Reply With Quote
Old 02-03-2006, 03:34 AM   #10
Cam1959
Question Re: heater only works in 2 positions!! HELP!!
my fan stopped working on any speed. i cleaned the ground wire connections. now it works but only in max, not 1,2 or 3.
so i guess i must change the resistors ? i think they are held on top of air box by 2 screws, with 3 or 4 wire female plug connected to their connector tabs ?
Cam1959 is offline   Reply With Quote
Old 02-03-2006, 03:38 AM   #11
dmbrisket 51
well first off, kinda an old thread, and second, if cleaning the high ground made the high work try cleaning the intermittent ground (high is controlled on a seperate relay system, same power feed, different ground) and depending on the year it could be a resistor pack or a 'modual'
Old 02-03-2006, 03:56 AM   #12
Cam1959
Sorry and thanks. I was searching to figure out what might be my problem which this thread seems to cover. I am only aware of a ground wire from motor housing screw to fender screw. I'm not sure where any other ground wire would be like you mention for the resistor speeds 1,2 and 3 ?
I'm guessing the resistors are what that multi-wire plug attaches to ontop of air box ?
I don't know where that relay is but it seems relay is okay if only my max speed works ?
1983 S10 4WD carbed 2.8L automatic w A/C
Old 02-03-2006, 02:17 PM   #13
Cam1959
Thumbs up Re: heater only works in 2 positions!! HELP!!
After reading this informitive thread, I was pretty sure my problem was my resistor module. I am so embarrassed because I had previously wiggled the 4-wire plug connected to resistor module ontop airbox and got no power on speed 1,2,3. I just went to pull-your-own wrecker. Before I went in i decided to take out my resistor pack to take in yard with me. It was hard to pry that plug off. Once off I see the plug female connectors and module male connectors are very rusty. Sprayed with wd40 and scraped the males. Put back on and now all speeds work. Good grief Charlie Brown. I had assumed since wiggling it before, that the connectors weren't the problem.
98 heater only works on Med/Hi & Hi barker23 Century 4 01-20-2005 12:04 PM
88 4runner Heater Only works with higher rpm's gearlicker 4Runner/GX470 1 01-17-2005 12:58 PM
Heater only works on High.. justrelaxing Intrigue 2 01-16-2005 12:46 AM
Heater only works on max please help tegL Accord/TSX/Accord Hybrid 4 01-07-2005 02:49 PM
Heater only works on speed 4 in 94 850 95xjsport 850 2 12-22-2004 05:48 PM
