Old 01-31-2004, 07:42 PM
hpmodz hpmodz is offline
Send a message via AIM to hpmodz Send a message via Yahoo to hpmodz
Question Any engine PRO's out there? (((((I need some help)))))
Let's talk Beef with Muscle. 443 - Cam; Roller rockers; (1.8/1.00) 20% Spring Pressure increase. Ran 30' than Broke 5/16" Hardened in Guides Push rod & found 1/4" ware on # 4 Ex. Anti-Pushup Lifter, & Maybe the same ware on the Cam Lobe. ---------- Could the problem be the rear cam bearing, in wrong? Not allowing oil?
your help is much appreciated!!!!!!
Old 02-01-2004, 06:55 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
what kind of engine?
Thats a pretty radical rocker arm ratio. Maybe the valve gear was binding, or there was too much lift, for the rocker arm geometry.
Old 03-10-2004, 01:22 PM
silver_chevelle silver_chevelle is offline
Re: Any engine PRO's out there? (((((I need some help)))))
it is possible there is wear on the cam because of your radical rocker ratio...hell, i did not know they even made a 1.8..i have 1.72. anyways, if the springs are too strong o they bind, you'll reduce power because the cam is being pushed on too hard by the lifter. if that happend there is no way to fix it except change springs and get a new cam. cams have HARD heat treated metal on the outside and are softer inside. once the outer cam wears on the lobe there is no saving the cam
Old 03-10-2004, 01:26 PM
also....the oil fills up through the lifter then pushrod and to the rockers...fall through the hols in the heads and back to the pan it goes...with a 5/16th head stud...well...its aweful small for anything above 5500...maybe 6...3/8th is perfect up to about 7500-maybe 8000rpm. but anyhigher than 7500 on regular use get a 7/16
any pros out there? i need help talonpunk831 Engine, Transmission and Drivetrain 1 11-14-2004 07:13 PM
is there any web sites out there that sell parts for 80-87 regals? FastTeen Regal 3 05-20-2004 09:46 PM
Are there any Murcielago replicas out there? 310motoring Murciélago (Murcielago) 14 05-11-2004 07:02 AM
Are there any Modded STS's out there? SniperX13 General Discussion 0 12-02-2003 08:30 PM
