| Search | Car Forums | Gallery | Articles | Helper | Air Dried Dog Food | IgorSushko.com | Corporate |
| Latest | 0 Rplys |
Show Printable Version | Email this Page |
#1 | |
I have a heater problem, I start the truck no heater motor,drive for a while and it turns on.
Please some one tell me what it is before i blow the truck up!!! |
#2 | |
Re: blower motor comes on when it wants to!
I am having a similar problem. I believe it is a bad blower motor. It just happened to me a day ago. With 10 degree temp's, I have to get it fixed.
#3 | |
I Had to change my blower motor this summer, It was only working a tiny bit, If you change it yourself like i did, Make sure the rookie at the store gives u the right part, cause i got a blower motor that turned the opposite way, i put it on, it ran but wouldnt push the air, then I figured out it was the wrong one, good luck easy instal, except if your outside then brrrrrrrr here in Canada.....
#4 | ||
![]() Join Date: Jan 2004
#5 | |
I used to have to kick my license plate light to get my blower to work.
#6 | |
Normally when you get intermittent starting in the blower motor like that it means it's time for a new blower motor. What happenes is that the brushes inside the motor are hitting a flat spot and usually a good bump will get it to shift enough to make contact. (I had both this problem and bad squealing when it did run) Just swapped it out and no problems anymore.
![]() ![]() 95 s10 Blazer, EGR Mod, ZQ8 Steering box mod, 99 Center console shifter mod and more... See everything at www.pghconsulting.net/teal |
#7 | |
check the wiring harness next to the computer in the passenger's side of the engine compartment. The wires may be loose, burnt, or just plain dirty. I had a similar problem. |
#8 | ||
