97 metro no ignition won't start
please help! i had to change the timing belt in my 97 geo metro lsi 1.3 engine put it all back together great however the haynes book stated i had to pull a connector apart that was next to the coil on the firewall and run a wire between the connectors then start the motor did that and then nothing! everything else radio heater blower will come on when the key is in the on position but the check engine light oil light under the speedometer will not come on and the engine will not start just turns over and over no fire to the coil i have checked all the fuses please any suggestions as to what i may have missed the car was running great before this.
Well, you only run the FUSED wire between D and E terminals on the diagnostic plug if you have the 6 terminal plug. 4 terminal plug you leave it be. Also, that wire between the firewall and the dist is a required ground. If you shorted anything, you may have blown the ingitor module.
