Old 01-31-2004, 06:28 PM
Serrin Serrin is offline
Send a message via AIM to Serrin
Amp HELP
I'm hooking up my (I know, not that great of a system) Sony Xplode 50X4 to an Orion Xtreme 400 amp. Whenever my head unit comes on, the fuses in the amp blow. What is going on?
Old 01-31-2004, 10:12 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
you got a short circuit in your wiring somewhere, your subs are bad or miswired, or the amp is just defective
first take all the speaker wires off of the amp and see if it still blows fuses, if it doesn't - check your speakers. If it does, recheck all your wiring, you probably have one strand of wire touching something it shouldn't.
Old 02-01-2004, 10:36 AM
Thanks for the response. I have unplugged everything except the 12v, the ground, and the remote start. As soon as it comes on, the fuses pop. I just had the amp tested at a car audio place, and they said it was good so I think it's my wiring. Any tips?
Old 02-01-2004, 03:50 PM
Audio Guy
are you 100% sure all the right wires are going to all the right places and absolutely no stray wires are touching each other, or a terminal it's not supposed to
Old 02-03-2004, 10:41 AM
{SOMEONE}Freaky {SOMEONE}Freaky is offline
Re: Amp HELP
hi I need some help with my 760 watt sony xplode amp I was running it all summer with no probs, now there's a red warning light that say's " over current" I havent moved anything or unplugged anything I dont know why all of a sudden it would give me this light after working perfectly all year, I dont know much about car audio as I'm just getting into it.. plz help I miss my pounding tunes
Old 02-03-2004, 03:08 PM
Haibane's Avatar
Haibane Haibane is offline
Send a message via AIM to Haibane
Re: Amp HELP
check the fuses...
www.cloudcity.deviantart.com
Old 02-04-2004, 06:42 AM
Unhappy
I have checked all fuses, they are fine what else could I look for?
Old 02-04-2004, 09:37 PM
Haibane's Avatar
Re: Amp HELP
checked remote fuse in deck, etc? check fuse buy battery?
Old 02-05-2004, 07:01 AM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Re: Re: Amp HELP
Those amps are pretty wimpy. Sony has lacked in quality over the last few years. I stopped carrying them because of it. Then, Sony wonders why they had to lay off so many workers
Anyway, I'd unhook the subs, check all the fuses, then check the power and grounds with a voltmeter. If that all checks out, your amp is toasted. Unfortunately, it is very common with these amps.
Old 02-09-2004, 05:04 PM
Audio Guy
I can only think of things that might cause problems ...... it's really hard to troubleshoot over the internet
