Go Back   Automotive Forums Car Chat > BMW > 3 Series
Old 01-31-2004, 01:35 PM
stevegiguere stevegiguere is offline
Angry blinker bulb replacement
I have a 2001 3251 sedan. the drivers side front blinker bulb is out. the manual tells you what to do to replace a bulb but it does not say how to release the 'hook' that holds the lense cover in place. can anyone help me? [email protected]
Old 02-18-2004, 12:05 AM
Greggy Greggy is offline
Lightbulb Re: blinker bulb replacement
I had a nearly identical problem. I have a 2001 325i sedan I bought used and the left front signal light went out last week. I also could not discern which way to press to release the hook. From other pictures in the manual I can tell the assembly is held in by the grey plastic tongue. That tongue is bifurcated and passes through a short channel and sticks out the other end, which you can see through the access hole just under the edge of the hood. I tried pressing down, left and right on the tongue and down on the channel, to no avail. Finally I called the dealer for assistance but they said it was covered under the maintenance contract so just bring it in. I ended up never getting advised how to do it. I think they don't want to lose the revenues from change bulbs. I will try other garages and watch here to see if you find out first.
Old 02-18-2004, 11:42 AM
323imankiks's Avatar
323imankiks 323imankiks is offline
you need a long screwdriver and place it in the hole and push the plastic hook down slightly that should realease the lense cover
"What happens here stays here" LAS VEGAS
Heater knob bulb replacement - 93 geschaef Camry/Camry Hybrid/Vista 2 02-16-2010 01:54 PM
2001 License Plate Bulbs Delawn Interior | Exterior | Appearance 5 07-31-2009 10:29 PM
Blinker Bulb Replacement ?? robroy55 Taurus | Taurus Wagon 8 11-16-2007 01:13 AM
Replacing front blinker bulb klotom CR-V 1 11-11-2006 11:04 AM
Q; Replacing rear blinker bulbs cheezwizard Intrigue 6 10-16-2006 06:08 PM
