Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 01-31-2004, 11:46 AM
projectsilvia97's Avatar
projectsilvia97 projectsilvia97 is offline
Send a message via AIM to projectsilvia97
H23a specs
The h23a comes in the 93 prelude, correct? what are the stock specs on this? does it come with vtec? i know these are all really stupid questions, but i don't know much about preludes. wish i did. thanks in advance.
Old 01-31-2004, 11:51 AM
94preludeSI's Avatar
94preludeSI 94preludeSI is offline
Send a message via AIM to 94preludeSI
Re: H23a specs
there are 3 types of engines-
f22b- 135 horsepower not sure tq.
H23a- 160 hp and 156 lbs/ft tq.
H22a1 vtec- 190 hp 158 lbs ft tq.
Old 01-31-2004, 11:53 AM
so the h23 doesn't come with vtec? does the h22 only come with vtec?
Old 01-31-2004, 11:54 AM
Re: H23a specs
Yep. You can swap an h22 head on an h23 block but its really expensive. But stock the h23 does not have vetc
Old 01-31-2004, 12:12 PM
SiGNAL748's Avatar
SiGNAL748 SiGNAL748 is offline
Send a message via AIM to SiGNAL748 Send a message via MSN to SiGNAL748
the h23's came in all 92-96 Prelude's under the "Si" trim.
Old 01-31-2004, 12:35 PM
AcesHigh's Avatar
AcesHigh AcesHigh is offline
Prelude Guy
Send a message via AIM to AcesHigh
Full H23a specs:
Type: 2.3L, in line-4, aluminum block
Displacement: 2259cc
Compression ratio: 9.8:1
Valve Train: DOHC, 4 valves per cylinder
Power (SAE net): 160bhp @ 5800rpm
Torque: 156lb-ft @ 4500rpm
NON VTEC.
The h22a block, however, is.
cali spec headers?? AHHKILLA Eclipse 2000+ 0 04-28-2009 01:03 AM
h23a to h23a jdm help! bill blakeley JDM Motor & Parts info/chat 0 09-27-2005 08:23 AM
JDM H23A specs? tkdfyter Engineering/ Technical 1 10-23-2002 06:54 PM
cost and ease of install on a h23a into a 3gen lude flylwsi Prelude 12 05-06-2001 09:30 PM
