Go Back   Automotive Forums Car Chat > Honda > Integra
Old 01-31-2004, 12:20 AM
skipnboy skipnboy is offline
jumping tach
just wanted to know if anyone can help me...my tach is jumping all over the place. dont know what it is. around 4500 rpms it also feels like im losing power. i.e. like the rev limiter is kickin in. sound familiar anyone? please help. thanks
Old 01-31-2004, 09:23 AM
tsugsr tsugsr is offline
Re: jumping tach
well first check your timing, then get a leak down and compression check, that can be done at most shops. if that doesnt fix it i dont know then. hope this helps
Old 01-31-2004, 10:05 AM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Re: jumping tach
What kind of car do you have? Integra right? GSR, LS etc? Need to know to further help.
Old 01-31-2004, 07:36 PM
Re: jumping tach
i have a 2000 LS integra
Old 01-31-2004, 10:31 PM
whtteg's Avatar
Re: jumping tach
Have you done any mods to it at all in the past couple weeks?
Old 02-01-2004, 02:44 AM
Re: jumping tach
no mods
Old 02-04-2004, 11:25 AM
Dave1979 Dave1979 is offline
jumping tach
you may want to check fuel pressure. sometimes if you dont have correct fuel pressure this will cause a misfire symptom. try this and let me know. remenber if you replace the fuel pump you must replace the fuel filter. tha main cause for fuel pump failure is a clogged fuel filter.
Old 04-13-2004, 03:19 PM
Steve Douglass Steve Douglass is offline
My tach was jumping around, but I had two igniters go out in the distributor prior. Suddenly the car wouldn't start. Turned out to be the Distributor. Had it replaced. Fixed that problem. Check that before you replace ECU. Also, make sure it's a factory. They can give you other problems if it's not. My first replacement turned on the check engine light at 2k RPM's like clock work. I had the Distributor replaced again under warranty, corrected the problem. There is a tach connection to the Distributor. Yours may not be a completely bad Dist., but related.
1999 LeSabre - strange short-term fix for speedometer and tach that sometimes works Taurus1997 LeSabre 8 01-07-2011 01:29 PM
Max AC Clicking/Tach Problem tominton Cavalier Problem Diagnosis 1 07-09-2009 03:27 PM
Escort 99 keeps jumping on first drive of day for about 150 Yards (CEL 0401) MyEscort99 Escort 4 04-02-2009 11:11 AM
2000 Lumina 3.1 Lights dim, tach jumps, often needs to be jumped Tuco1369 Lumina 2 05-01-2008 06:58 PM
Jumping Tach? explicit408 Rodeo | Passport | MU 4 02-12-2007 01:35 PM
