Old 01-30-2004, 11:30 PM
mrfixit247 mrfixit247 is offline
Send a message via Yahoo to mrfixit247
89 S-10 Blazer height
I was wondering if anyone knew what the heighth of my Blazer should be? My S-10 sits 2 inches higher on the front (from top of tire to bottom of wheel well) , then in the rear. It kinda looks weird to me.
Old 02-02-2004, 03:07 PM
TexasF355F1's Avatar
TexasF355F1 TexasF355F1 is offline
Send a message via AIM to TexasF355F1
I'm not positive, but your leaf springs could be worn out. You can usually get the re-arched. Or you can get a new set.
*Under Construction - New sig to debut*
Old 02-02-2004, 10:04 PM
TopDogg TopDogg is offline
If its 4x4 someone could of adjusted the torsion bar up front. But even if so you still should raise the rear. If back rides as if its worn out you should replace leafs. You can take a quick cheap way out anf buy a set of 2 inch add-a-leaf kit for the rear. That should raise it up. Fairly cheap. Of course there are mixed opinions and some might even say a shackle lift but if they are worn forget the shackle lift.
Old 02-02-2004, 10:22 PM
Re: 89 S-10 Blazer height
How can I tell if my leaf springs are bad?
S-10 Blazer fuel sensor overheating Lisa48616 Problem Diagnosis 2 05-20-2010 08:18 AM
1996 S-10 Blazer DTC Problem (P1192) arthurjohn Problem Diagnosis 17 02-16-2010 07:09 PM
1989 S-10 Blazer Wiring Diagram 89S10Blazer S-10 1 01-07-2010 10:01 AM
S-10 Blazer stalls when engine is hot christian1218 Problem Diagnosis 25 10-19-2009 12:23 PM
96' Blazer - Arizona Heat vs S-10 Blazer Marcinko Problem Diagnosis 5 05-18-2007 04:17 PM
