Old 01-30-2004, 09:31 PM
ooljima ooljima is offline
Send a message via AIM to ooljima
Help!!!!???
i got these generic ic pipes that are wannabe greddy..... i installed.... it kept popping off...... so i put the stock ones back on. now it seems like i lost so much performance..... even more than i had before i put the aftermarket ones on... god damn.... somebody help!!!! should i just reset the ecu cut i took it apart like a million times...... and yes i did drive for like 1/4 a mile when the pipes popped off.... god damn... car seems so slow!!!!!!!!!! help me.... what can i do?...
Old 01-31-2004, 08:54 AM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
resetting the ecu can't hurt ... i read somewhere that after you add aftermarket parts you are supposed to reset the ecu.
For Sale 98 Eclipse GS, 5 spd
Old 02-01-2004, 05:37 AM
GSX Creep GSX Creep is offline
Re: Help!!!!???
I had the same problem.
I flared the ends.
How did you reset the ECU?
Old 02-01-2004, 02:09 PM
gs-t spyder gs-t spyder is offline
Re: Help!!!!???
you will have to get the ends flared like said above then you will not have any problem with them coming off and yup that sucks because i had made the lower intercooler pipe and didnt have the end flaired and had the same problem and i know it sucks. good luck.
Old 02-01-2004, 02:12 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Help!!!!???
REsetting the ECU will more likley hurt than help, for a short time anyway. The ECU constantly adjusts. If your parts make any difference, it will compensate within 5 minutes of idling, and 10 minutes of steady cruise.
Flaring the ends is the best thing to do. I just use some vice grips or channel locks to bend the end out slightly. You can also spray some hair spray on the end before you slide the coupler on
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
