Old 01-30-2004, 08:27 PM
slammedcivicsi's Avatar
slammedcivicsi slammedcivicsi is offline
Using Integra Solonoids with B18 Swap
Im using the Purge Cut-off solenoid aswell as the Pressure Regulator Cut-off Solenoid.....My question is that the 88-91 DX civics only use the Purge Cut-off Valve.....so when I go to run the Pressure Regulator Cutoff solenoid....should I just use the OEM Connector....and run the Extra wire to the ECU.....there are 4 wire.....Green, Green/Yellow stripe, and 2 Blacks with Yellow Stripes....Obvious the Black with Yellow Stripes are grounds.....the the Green will connect to the green wire (Purge Cutoff Solenoid......now my big questioin is the left over Green/Yellow wire....(Pressure Regulator Cutoff) What ECU Pinout would it go to....and how or where should I connect it...I want to run the Integra Solenoids simply for emmisions....and Because I got rid of my crap.....whats everyones opinions..
Thanks
Brad
89 DX: LS Powered
88 CX: Project ZC
Old 01-31-2004, 07:02 PM
91civicDXdude's Avatar
when i did my b18a1 swap, i just didnt use the fuel pressure cut off solenoid. civics dont have it, and the car ran fine, so i guess it doesnt need it.
Old 02-01-2004, 01:55 PM
Re: Using Integra Solonoids with B18 Swap
Ya...Ive looked at your swap pics....Im just gonna use the DX solonoids....I got some from a recycler today.
89 DX: LS Powered
88 CX: Project ZC
95 Integra LS with B18 A1 VSS location? cwshifflett Integra 1 02-05-2011 08:32 PM
Need Help With B18 Swap Map Sensor?? Twyztidmind '88 - '91 Civic | CRX | Wagon | Shuttlee 2 05-03-2005 08:39 PM
Need Help With B18 Swap! Twyztidmind '88 - '91 Civic | CRX | Wagon | Shuttlee 2 04-29-2005 01:39 AM
92 Civic Hatch I Need Help With B18 Swap! Twyztidmind '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 04-01-2005 09:47 AM
making cold air fit with b18 swap henry matyjewicz Let's get Technical! 7 06-05-2004 02:31 AM
