Go Back   Automotive Forums Car Chat > GMC > Jimmy
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 01-30-2004, 05:03 PM
Loud_Aurora Loud_Aurora is offline
Starting trouble
I have a 94 Jimmy with the 4.3 Vortec(fuel injected). The problem is that sometimes it won't start, it will turn over with no problem but won't start. If I jump it with another vehicle it will start almost instantly. I put a new battery in it and had the alternator checked and was told it was okay. Then a shop said that it wasn't getting enough fuel pressure to start and that the pump was bad, I changed the pump and still have the same problem. Does anyone know whatelse it could be?
Old 02-02-2004, 02:09 PM
mjohn mjohn is offline
Re: Starting trouble
does it run rich...idle rough?
Poor gas milage?
Old 02-02-2004, 11:58 PM
herefordman herefordman is offline
Sounds like it needs a distributor cap, rotor, wires, plugs, etc.
Old 02-05-2004, 04:02 PM
Re: Re: Starting trouble
Poor gas milage?
It idles rough when I start to put a load on the electrical system(ie. turn on the heat).
Old 02-05-2004, 04:03 PM
This is actually the next step that I have planned, plugs and the module under the distributor cap.
Old 02-09-2004, 05:29 PM
Problem solved, it was the fuel pump relay located on the driver-side of the firewall. The connection was bad so we cleaned it up and it has been fine ever since. I will be replacing it within a week or two just to be safe.
Closed Thread
