Another wiper problem
The driver's side wiper isn't moving at all and the passenger side wiper is working fine. I removed the cap and bolt from the wiper which wasn't working, the thread doesn't look stripped out or bad ... with those off I turned the wipers back on and still didn't see any movement from the post --- what to do or look for from here ? thx. dan
Nissan Altima wiper problem
Nissan Altima, 1997 Sedan.
I have the very same problem. Driver side wiper NOT working and only the passenger side is working. It happened when I put the wiper on, and the driver side wiper swung to it's max swivel position and stopped. But, passenger side is working fine. |
Re: Another wiper problem
your wiper linkage came off of the pivot under the cowl
Re: Re: Another wiper problem
i'm a nissan tech. you might have to remove the pivot that the wiper bolts to. should find three bolts that fasten it to the cowl the reach in and grab it and pull it out. the linkage has plastic ball sockets you might be able to snap it back together but if the socket is wore out you'll have to buy a new linkage piece from the dealer. replaced one on a sentra a couple of weeks ago and I think it was under 12 dollars
