Old 01-29-2004, 11:20 PM
wdias1 wdias1 is offline
1994 Park Ave Dies
I have a 1994 Park Ave. I had the transmission overhauled @ the dealers. Two days later, the car would not start. I would remove the negative termial from the battery, replaced it, then it would start right away. Then a few days later, the car would just die as it was running. The radio, the IP lights, A/C, everything died. I would have to limp the car over to the curb, when I placed the car in park and turned the key, nothing. No crank at all. The only thing I could do to start the car was to take the battery cable off and put it back on. I replaced the battery, it was only a year old, and it did the same thing.
I have been fortunate that when the car died, it died on side streets and strip malls. I am worried that this will happen on the freeway with my family in the car. Picture the car just dying on the freeway with no notice. It does not sputter or run funny at all, it just dies as if it was unplugged. No brake lights or signal lights to let anyone know. We would have to jump out of the car and get to the side of the road. I would feel badly for anyone coming around the corner.
This same thing happened to a co worker of mine with a 1994 Park Ave too, except his was on the freeway at night. Everything went out. headlights, everything. He was able to roll off the road and restart the car.
I was told a freind's car did the same thing (Trans AM), it was a problem with the PassKey II. I know there may be problems starting the car because of the security system, but would it effect the car like this when it is running ? Would it take out the lights, turn signals ?
Please help. This has been making me crazy. I don't trust the car right now, makes me very nervous to have my family in the car like it is.
Old 01-30-2004, 11:26 AM
jon@af's Avatar
jon@af jon@af is offline
The Media Guy
Send a message via AIM to jon@af
Re: 1994 Park Ave Dies
You'll probably get more responses in the buick forum.
AF User Guidelines <----Click and read if you don't know these.
"Dream as if you'll live forever. Live as if you'll die today."
A Blog By Swigz
Cotidie damnatur qui semper timet; Aquila non captat muscas.
Old 01-30-2004, 11:57 AM
RABarrett RABarrett is offline
My suggestion would be to check two things: One would be the positive lead to the battery, where it interfaces wioth the vehicle. Though these are typically on the starter, they are at times on terminals elsewhere. You might also check your ground connections. The anti-theft should not affect the lighting. Since the trans was out of the vehicle, I suspect loose terminals somewhere. Ray
Old 01-30-2004, 05:03 PM
ks0309 ks0309 is offline
could it be a circuit breaker ,or fuse, under the hood in the fuse box that overheats and kills the power and it does not reset until you disconnect power by means of the bat. cable. see if any circuit breaker get overly hot while its running, might need to replace one.
'95 Park Ave OBDI port location? GMLoyalist Park Avenue 2 04-14-2009 12:57 AM
1994 park ave, dies every 2-3 days dextra Park Avenue 6 12-25-2005 03:39 PM
1994 Park Ave - Broken Rear Control Arm Bushing Bolts murphyjr Park Avenue 2 11-26-2005 02:11 PM
1994 Park Ave Won't Shift Landru Park Avenue 2 10-26-2003 06:36 PM
1994 Park Ave, Keyless?? KEVINS800 General Discussion 0 11-21-2002 06:33 PM
