Old 01-29-2004, 12:05 PM
KoRnSaQ KoRnSaQ is offline
Send a message via Yahoo to KoRnSaQ
Problems!
OK, so i was driving to go to work today, and halfway there on the interstate i was goin about 90 and all the sudden my car starts missin real bad, and it has been doin it since, it misses like crazy, it cant hardly hold an idle and it is backfiring quite a bit, but it is not smoking at all, I think it might be the distributer, cause i have already replaced the plugs, plug wires, and fuel filter. I just thought i would get some feed back from you guys before i start taking shit appart. Any help would be appreciated.
KoRnSaQ
Old 01-29-2004, 02:17 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
Check the timing.
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 01-30-2004, 07:47 AM
well i replaced the distributer and roter button, that helped a little but not much, i think i also broke the donut gasket(the one at the downpipe)I am goin to check the timming later today to see if it is off.
KoRnSaQ
Old 01-30-2004, 12:57 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
sounds like the rotor set screw came out, that happened to me before
Old 01-30-2004, 02:11 PM
for some reason i dont think i am getting a spark on the 3rd cylinder now, i replaced the roter button, the distributer cap, then i had to replace the plug and the wire for the third cylinder. Do you think it might be the actuall distributer that is causing it not to spark????
KoRnSaQ
Old 01-30-2004, 02:38 PM
1PhatCX's Avatar
did u put a whole new rotor on??
are u sure the wires are on tight enought? did u pull the plug and check if u have spark??
Old 01-30-2004, 03:13 PM
like i said i went ahead and switchedout that plu and plug wire to see if that would work but it didnt, see i figured this cause while the car is running i was pulling the plug wires out one at a time, and on the third one when i pulled the engine still sounded the same, as with the other ones the engine bogged down whenever i pulled them so i know they are still workin right. I also replaced the roter button and distributer cap yesterday and that didnt seem to really help much, The only thing i can think of is that it is the distributer. if you have any other suggestions please tell me.
KoRnSaQ
Old 01-30-2004, 08:34 PM
SiZ's Avatar
SiZ SiZ is offline
Re: Problems!
Codes?
"The nympho of info, I'm fuckin' what ya heard"
Old 01-31-2004, 02:33 AM
i checked the ecu for codes, but to my supprise it wasnt throwing any,
KoRnSaQ
Old 01-31-2004, 03:41 AM
SiZ's Avatar
SiZ SiZ is offline
Re: Problems!
Could be your headgasket!?
Old 02-01-2004, 08:57 AM
Re: Re: Problems!
Ya, that is what one of my friends said, I am goin to run a commpression test on it today, maybe that will tell me something
KoRnSaQ
Old 02-01-2004, 01:54 PM
SiZ's Avatar
SiZ SiZ is offline
Re: Problems!
That is exactly what I went through with my DX motor, and it was the headgasket.
But I had a warantee on mine, so I got it fixed free then yanked the motor like a week later.
