Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 01-29-2004, 11:49 AM
H22A/EGcivic H22A/EGcivic is offline
Lightbulb H22A to a civic swap
I am swapping a H22A into a civic and i was wondering if my factory civic radiator will work until i can get a bigger one, or will i need to go ahead and get the factory prelude radiator when i swap the motor?
Old 01-29-2004, 12:16 PM
pheurton-skeurto pheurton-skeurto is offline
Re: H22A to a civic swap
youre going to need a bigger radiator...im not sure #1) if a prelude radiator will fit (im sure it probably will, or you can make it work) or #2) if a teg radiator will work.
for sure though you are going to need a bigger radiator...bigger engine=bigger radiator.
1997 Honda Prelude Base
18G Turbo - 8 Psi
GReddy EVO Catback
1995 Honda Civic LX
Bone Friggin' Stock
Old 01-29-2004, 02:21 PM
_~Hapex~_ _~Hapex~_ is offline
hey im doing the same swap, what problems did you have with it,
Old 01-29-2004, 03:19 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
My buddy has had his h22 in his civic for right around a year now and he's used his stock civic radiator the whole time without any problems. The blades on the fan of the radiator is pretty close to his slave cylindar thought, and i've heard a ton of people say that the stock fan is too big and they usually trim it or get one that is thinner. But who knows if my friend is just lucky his radiator works fine; so I'd definently recommend an upgrade. But you're probably still looking at trimming or getting a thinner fan if you do upgrade to a larger radiator.
Old 01-30-2004, 10:26 PM
darkerdayz darkerdayz is offline
Send a message via AIM to darkerdayz Send a message via MSN to darkerdayz Send a message via Yahoo to darkerdayz
as long as you dont plan on running it hard every single day, the stock radiator will do you fine. after a few "spirited" driving sessions though, you might notice that it may start to over heat just a little. so i think that you can run the stock radiator for now, but for maximum performance, eventually go w/ an aftermarket one.
and i dont think that the 'lude radiator will fit into the civic.
friends don't let friends drive stock
H22a Civic Swap Guide CivicSpoon '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 36 04-05-2010 02:15 AM
94-95 civic swap civicsavvy '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 0 09-25-2009 03:57 AM
h23 swap 4th gen civic? 92lude91dx '88 - '91 Civic | CRX | Wagon | Shuttlee 4 03-16-2009 12:43 PM
H22A Engine Swap ScreamingSun '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 06-12-2003 07:51 PM
