Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora
Old 01-29-2004, 09:08 AM
greennike's Avatar
greennike greennike is offline
Exclamation TDI Stalling/ODB Bypass
I have a 2001 Jetta TDI with 85000 miles on it. Yesterday I was driving down the interstate at about 80 MPH and it started to lose power and stalled. After about 30 seconds I got it to start again and drove for about 3 miles and the same thing happened. I limped it back to town, stalling every 3 miles or so and restarting after a couple of seconds.
It was -10 outside so i thought maybe it was gelling up, so I stopped at a gas station and bought some anti-gel, but it did not help, as a matter of fact the check engine light came on right afterward.
If i kept the car about 2000 RPM's it it took a lot longer to stall. It seemed to be truly affected when I gave it a lot of gas or if it was underpowered (in too high of a gear.)
I had it in my garage (heated) overnight and put a new fuel filter in it and started it up. I have not drove it, as the check engine light is still on.
my question is two part:
1.) I have an aftermarket radio installed by the previous owner. The connector is not there (they cut it off and spliced the wires. Therefore I can not hook up my scan tool. Does anyone know a bypass fot the ODB through the radio?
2.) any suggestions on what the stalling could be?
Thanks.
Old 01-29-2004, 10:43 AM
greennike's Avatar
Tdi Stalling Update
UPDATE:
I found out how to bypass the radio (disconnecting the grey/white wire)
Anyway, I have a trouble code P1248, which is fuel injection control malfunction"
Any Ideas?
Old 02-01-2004, 07:39 AM
dszakal dszakal is offline
I have a 1999 Jetta TDI that has identical symptoms. My initial thought was to replace the fuel filter. Did replacing the fuel filter solve your problem?
Old 02-02-2004, 07:48 AM
greennike's Avatar
Thumbs up Replaced Fuel Filter/Anti Gel
Well,
I replaced the fuel filter and added 911 anti-gel per the bottle reccomendations. Have been driving in -20 conditions and the problem has not returned.
Old 02-02-2004, 12:53 PM
boschmann boschmann is offline
Re: TDI Stalling/ODB Bypass
Code 1248 can indicate that the car ran out of fuel. Very possible fuel gelling of clogged filter. Have you checked for water (ice) in the fuel?
tdi stalling latique Espace 2 09-19-2006 07:47 AM
04' Jetta TDI, stalling when cold??? wenzel '04+ 3 05-23-2006 09:31 PM
2000 Jetta TDI Stalls at Operating Tempurature in Colder Weather j.scott Jetta/Vento/Bora 1 01-07-2005 12:51 AM
1996 Passat TDI stalls at speed ktm450exc '93 - '96 3 08-31-2004 05:14 PM
passat tdi stalling at idle jason261270 Passat 4 06-03-2004 05:27 PM
