Old 01-29-2004, 08:11 AM
Magik Si's Avatar
Magik Si Magik Si is offline
Ride Control - Bang For Your Buck?
Just a quick question...lately I've noticed that my pour little 90 HB si is starting to ride like a buckboard...and I noticed it a little in my old STD too...
So for the question...
What would be the simplest, cheapest, and longest lasting improvement to make my ride more comfortable?
I don't want to go nuts and do the whole lowering, special coils, super duper gas from mars filled shocks...I don't care if I can adjust my shocks because the area of the road I'm driving on has a lot of small animals and I might hit one...I just want...a nice comfortable ride.
Suggestions?
Jason
www.jasonlorette.50megs.com
90 Civic HB Si - D15B1 + MPFI
Old 01-29-2004, 08:36 AM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
Re: Ride Control - Bang For Your Buck?
tokico shocks and tein springs too many combinations to name
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 01-29-2004, 08:54 AM
Magik Si's Avatar
Oh...I'm also a little confused...one mechanic told me that I have struts not shocks...another told me I have shocks not struts...one told me I have struts in the front and shocks in the back...sweet geezuz?
What's stock on a 90 HB Si? At least that way I can know where to begin?
Jason
Old 01-29-2004, 10:01 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
struts on all corners is stock.
you want a comfortable ride that will last, get new stock parts.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 01-29-2004, 12:40 PM
BLU CIVIC's Avatar
調整器
to simplify it....just call them dampers
The name's Adrian
2011 CR-Z - Stock
Old 01-29-2004, 03:48 PM
4GZChatch's Avatar
4GZChatch 4GZChatch is offline
Send a message via AIM to 4GZChatch Send a message via MSN to 4GZChatch Send a message via Yahoo to 4GZChatch
You can pick up stock-style shock absorbers (the part inside the spring, that eliminates the "buckboard" feel) from most tire shops for about $25 apiece. If you want a better set, you can pick up KYB GR-2's from somewhere like the tirerack.com or expressautoparts.com for about $40 apiece. It would probably be good to replace your springs at the same time, since they are probably really worn out, and I like Progress or H&R for the money. I can get a set of progress springs for your car for about $150 plus shipping to your door, which I think is a great value, since they ride really nice, without the "goKart" feel, but tighten it up noticeably. That's my $0.02, lemme know if you wanna order a set of springs...
Remember: You can't spell Crap without APC!
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Hyperco GenII suspension
Progress sway
SAFC
etc. etc.
Old 01-29-2004, 09:10 PM
BullShifter's Avatar
Re: Re: Ride Control - Bang For Your Buck?
Struts have springs mounted as 1 assy.(honda)
Shocks are seperate from springs
I'd recommend either stock springs or H&R's minimal drop(.75" i think) for a comfortable ride. I would also suggest upgrading the struts if lowering with KYB GR2's or Tokico HP's, stock struts can be used if not lowering.
www.tirerack.com - decent H&R prices
Old 01-30-2004, 12:45 AM
4GZChatch's Avatar
I forgot to mention that you can use 1G teg springs in our cars to maintain almost stock ride height and get a much stiffer ride. I had this setup for about the last year, and it rode really nice. It lowered the car enough to eliminate some of the wheel gap, but not enough to cause camber problems.
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Progress sway
SAFC
etc. etc.
Old 01-30-2004, 06:34 PM
feelsfast feelsfast is offline
Send a message via AIM to feelsfast
If you just want the same ride height and a better ride go get 4 new stock struts the ride will be like new again. I have an accord that has no mods at all and I did the above and it was like a new car again. 2 front struts were like 80 bucks and since they aren't being used with lowering springs I won't have to replace them anytime soon. Plus they have a warranty.
Yes my car is slow!
