Old 01-29-2004, 04:46 AM
David_ David_ is offline
dried acrylic paint...
i seem to have totally stuffed up my rear windows.... i was wondering how do i remove totally dried acrylic paint.? do i need acrylic thinner? or can i remove it by washing with warm/hot soapy water?.
Old 01-29-2004, 04:56 AM
chrismcgee's Avatar
chrismcgee chrismcgee is offline
WWW.ELITESCALECARS.CO.UK
i use acrylic thiner on a cocktail stick, soak the end of a cocktail stick for thirty seconds in tamiya acrylic thinner X20a then use it to push and scrape away the paint. its extremely neat. i use it to clean up areas where paint runs under the mask
Old 01-29-2004, 06:08 AM
iceblend's Avatar
iceblend iceblend is offline
Re: dried acrylic paint...
Or u can soak the parts with window cleaner, leave it for half a day and the dried paint will be gone.
Work In Progress
Old 01-29-2004, 02:31 PM
Harlock Harlock is offline
Recently had this same problem.
See here: http://www.automotiveforums.com/vbul...d.php?t=180808
A lot of good advice, but I found brake fluid (NOT CLEANER!) to work the best.
Old 01-29-2004, 09:11 PM
935k3's Avatar
935k3 935k3 is offline
If it is Tamiya Acrylic soak it in Ammonia(main ingredient in window cleaner). It will come off in 5-10 minutes with absolutely no harm to the clear plastic.
Old 01-30-2004, 12:56 AM
kewl thanks. another question.... how do i do customised liscenced plates?.... put the numbers onto decal, then soak whole ting in water? or apply main decal, then apply numbers aftewards?
Old 01-31-2004, 06:44 AM
anybody know?
Old 01-31-2004, 09:08 PM
yes? no?
