Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 01-29-2004, 12:38 AM
justkoolman justkoolman is offline
B16A or B18C?
Which swap gives a better performance. A 1600 Civic Head on a CRV Block or an 1800 Integra Head on the CRV Block. I have a choice to make between the two of them soon and don't know which one to go for. So please help me out.
Old 01-29-2004, 08:41 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
the b16a head flows more freely than the b18 does, so that would be my choice.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 01-29-2004, 02:37 PM
jcrx jcrx is offline
Send a message via AIM to jcrx
Re: B16A or B18C?
But the GSR head has a higher compression due to the shape of the chambers
Old 01-30-2004, 09:04 AM
crxlvr's Avatar
compression can be changed alot easier than the flow characteristcs of the head.
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 01-30-2004, 03:52 PM
Re: B16A or B18C?
Will considering the B16A head only flows better by a fraction of a percent, and only in a small segment of the rpm range (granted it is the most important segment), I'd rather spend a little for a slight port and polish than rebuild a block with new pistons, which would cost more. Of course he could run a thinner head gasket, and hope it holds under hard abuse for long enough to make it worth it, or he could do the worst and mill the head, but once you take it off, you can't put it back.
Old 01-30-2004, 04:05 PM
Spectre927's Avatar
Spectre927 Spectre927 is offline
Send a message via AIM to Spectre927
What's the cost of the heads? Im guessin you'll be able to get the B16 for cheaper
Old 01-30-2004, 04:08 PM
Re: B16A or B18C?
I've seen more cheaper B16A heads, but have seen my fair share of cheap GSR heads too. Depends on how much you look around, you can find both comparitively priced.
Old 01-30-2004, 05:40 PM
emerge's Avatar
emerge emerge is offline
Send a message via AIM to emerge Send a message via Yahoo to emerge
Re: B16A or B18C?
My vote is the B18...
Stephen Gladney
Original PH Member
EJ8 Civic | AIM: nxzo | www.rtek.org
Old 02-12-2004, 04:51 PM
dealgrabber2002 dealgrabber2002 is offline
Send a message via AIM to dealgrabber2002
Re: B16A or B18C?
me too.. B18 is a bit better than B16
Old 02-12-2004, 05:17 PM
boosted331 boosted331 is offline
Re: B16A or B18C?
Alaniz had flow data up for a stock B16 head and a stock GSR head, the numbers were virtually identicle, within a few CFM's at any given point on the chart. That small difference can be attributed to casting inconsistencys, and you wouldn't notice that small of a difference anyways. Go with whatever head you can get cheaper.
Old 02-12-2004, 05:19 PM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
Re: B16A or B18C?
how about both. B16A head does flow better than the B18. Also, B18C block + B16A head = poor man's Type R engine. Also, you can replace B16A head parts with B16B parts.
Empty Pockets Racing Member #1
Old 02-14-2004, 05:13 PM
projectsilvia97's Avatar
projectsilvia97 projectsilvia97 is offline
Send a message via AIM to projectsilvia97
if you use the "search" button, you can find a million arguments on this topic.
Old 02-14-2004, 08:24 PM
Spectre927's Avatar
Re: B16A or B18C?
Its kind of like arguing about whether God exists or not. You can't prove he does, but you can't prove he doesn't. Even with charts and dynos, people will still differ in their opinions.
Who wants one of these?
Old 02-15-2004, 09:02 AM
syk_pal_jgomez syk_pal_jgomez is offline
Send a message via MSN to syk_pal_jgomez
b18
isnt the ls motor with like type r head a better combination than both of those
Old 02-16-2004, 02:11 AM
Spectre927's Avatar
Re: b18
Theres almost no point in paying for a type r head when you can have a b16 p&p'd
