Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 01-28-2004, 05:13 PM
94AccordEX 94AccordEX is offline
Problem with COLD start..
It has been freezing here recently and when I go to start the car first thing in the morning, it would crank for like 3 seconds and cough briefly but does not start. Then I try again and it does the same. Then on the third try, it starts immediately with almost no cranking. Then throughout the day whenever I shut it off and start again, it starts with no problem at all. The problem is only during the first start of the day. Has anyone ever had this problem and how did you fix it? I am afraid it might be something serious or expensive to fix. Thanks all.
Old 01-28-2004, 09:47 PM
Privatebigandrew's Avatar
Privatebigandrew Privatebigandrew is offline
Send a message via AIM to Privatebigandrew Send a message via Yahoo to Privatebigandrew
Re: Problem with COLD start..
When you turn your key, let it sit in the ign. position for a few seconds. This will let the fuel pump build pressure in the lines. Try cranking it then and see what it does. it may just be a fuel filter, or even the type of gas you are getting. Maybe the station hasnt switched to winter gas yet? always check the easy things first.
94' Del Sol VTEC (B16A3) SOLD.
Accel plug wires, NGK iridium IX plugs, AEM short ram intake, DC sports ceramic coated header (4-2-1), Airmass high flow cat ,Custom Magnaflow exhaust, Bosal Brospeed tips, Neuspeed short throw shifter, Tokico clutch master cylinder, Tokico clutch slave cylinder, Prothane complete kit bushings, Brembo front rotors, NR EL-Glo instrument gauges, CTR LSD trans with ITR final drive, Exedy chromoly flywheel, ACT HDSS clutch kit, Raxle axles.
Old 01-30-2004, 09:34 PM
darkerdayz darkerdayz is offline
Send a message via AIM to darkerdayz Send a message via MSN to darkerdayz Send a message via Yahoo to darkerdayz
also, maybe your battery doesnt have enough cold cranking amps to start your car when its cold. i had the same problems w/ my 90 accord, and when i changed batteries, that problem went away instantly. but, i agree, you should check the easy things first before havin to shell out the big dough.
friends don't let friends drive stock
Old 01-31-2004, 08:06 AM
Rover 2 Rover 2 is offline
I had this problem with mt 89 SEI. It is very frustrating, however the problem was that the injectors were leaking down the fuel pressure.
It takes a few seconds for system to pressure back up but if injector is leaking it is also dumping fuel into cylinder which causes that cylinder to have to much fuel causing a flooding effect. The ignition systems today can most of the time handle this because of the very hot spark produced.
I removed the injectors and had them cleaned and tested. Since they were ok new seals were installed and I reinstalled them. This was much cheaper than the money for new injectors.
Good luck Rover2
