Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 01-28-2004, 01:43 PM
_tha_lude_ _tha_lude_ is offline
Need 4th Gen H22 Conversion Help!!!!
I HAVE A 93 PRELUDE Si, I just put in a h22 j-spec with lsd, axles and everything mounted up, with the exception of the exhaust....... But I am running into problems with the wiring, the easiest is the vtech I think I got that, except I dont know if that senser behind the valve cover is the pressure plug or not. The main problem is with the coil, h23 was an external coil, h22 is internal, does anyone know which wires need to be switched into the harness to make the coil work???????
Old 01-28-2004, 02:14 PM
Re: Need 4th Gen H22 Conversion Help!!!!
help help help
Old 01-29-2004, 12:26 AM
Unhappy
still needing help
