Go Back   Automotive Forums Car Chat > BMW > 3 Series
Old 01-28-2004, 10:37 AM
beamer adam beamer adam is offline
Unhappy Head Gasket-need help
guys i need to know has anyone had a head gasket replaced in their beamer? i have a 97 316i with 50,000 miles and blew the head on it. will the car be good as new again or will i have problems from it after. how much did it cost you to do? the oil is gone white sludgey and coolant system is rock hard overpressurised.whats your advice?
Old 03-04-2005, 04:26 PM
joesbmw joesbmw is offline
Re: Head Gasket-need help
if done by the book and the head is not warped or cracked it should be fine. oil is white because the coolant has entered the lubricating system. changed heads and gaskets on all kinds of engines get a book and dont deviate from it
Old 03-10-2005, 01:43 PM
Fred D Fred D is offline
Yes I have 1999 BMW 323i. I cracked the head and had to have it welded. I took the head in to a shop to get it welded but I did all the rest of the work will the help of my dad. The total cost was about $1000. After the job was completed the car ran good as new. Just make sure you follow the book.
Old 03-10-2005, 01:57 PM
Skycity_BMW's Avatar
Skycity_BMW Skycity_BMW is offline
Send a message via Yahoo to Skycity_BMW
Adam . . . you should just put a M50 motor in your 316i and make it a sleeper . . if not you can buy the long block version of the M40 motor.
