Old 01-28-2004, 10:29 AM
trailcarnage trailcarnage is offline
Angry Just failed emissions!
My wife just called to inform me that her 1997 Blazer failed emissions. I did a quick search for the codes that were read: P0740, P0753, P0758, P1860. What I found was an archive from here: 1998 Jimmy Check Engine Light It appears that this gentleman had the identical failure.
The light came on the day that I installed a remote starter on the vehicle. The transmission also acted strange once that day. When pulling up a parking lot, the transmission slipped as if it were in a higher gear that it should be. This hasn't happened since but the light still comes on from time to time. Could this be "noise" in the line from a loose connector causing the ECU to get false reading?
Any suggestions would be greatly appreciatted!
Tom
www.trailcarnage.com
Old 01-29-2004, 08:31 PM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Re: Just failed emissions!
Tom
You MUST be certain that the white or pink/white wire is hooked up. If not, tranny failure is certain. It also causes the vahicle to make the ECM go into default mode which would make you fail emissions. I was also told that if you run high octane gas makes it fail too???
Failing emissions 2005 Ford Taurus HELP! JenniferTNPLH Taurus | Taurus Wagon 4 03-03-2010 11:28 PM
Just failed my NOX emission – please help juno Grand Cherokee | Grand Cherokee SRT8 3 08-06-2008 08:45 PM
Failed Emissions current2 Camry/Camry Hybrid/Vista 4 05-04-2004 06:49 PM
