Go Back   Automotive Forums Car Chat > Buick > Roadmaster
Old 01-27-2004, 10:26 PM
simperry simperry is offline
94 roadmaster estate wagon
have a 94 estate wagon with problem with clima control. when car heats up i barely get warm air from heater. can set temp to 90 degrees but doesn't help. temperature gauge only goes up about less than mid way. is there a possibility that have wrong thermostat in vehicle or can anyone give me addtl guidance as to what to look for to correct problem. how hard is it to change thermostat on this vehicle. thanks
Old 01-30-2004, 11:20 AM
comp comp is offline
not sure on yours, stop at the parts store and get a shop book on your
car and see, may be easy ether way you'll know more about what is going on with it even if you don't work on it
Old 02-16-2004, 11:16 PM
jctedder jctedder is offline
Re: 94 roadmaster estate wagon
Have also 1994 Estate wagon w/350. It's leaking coolant (small leak) from rear of engine, w/ no obvious leak from anywhere. Are there freeze plugs/expansion plugs in the rear of the block on this engine? thanks
Old 09-10-2004, 11:06 PM
gn1220 gn1220 is offline
Re: Re: 94 roadmaster estate wagon
Yes, there are freeze plugs in the back of the heads. Check the heater lines coming out of the heater core. Mine were leaking there from the factory fitting.
Old 11-05-2004, 09:53 AM
manlion manlion is offline
I had a problem with heat also. After a while I happened to find my old thermostat. Lo and behold I noticed it had a large spring and a smaller spring. The part I bought at Murrays only had one spring. I went to dealer and bought the part About $25. After putting it on it worked fine. Very easy to change also, by the way.
Old 12-21-2004, 07:37 AM
Windssurfer Windssurfer is offline
Check the heater core
Have your antifreeze changed and find a shop that will powerflush the system including your heater core. Sounds like a blocked heater core is preventing the heater from getting hot... It's a good time to have the thermostat changed as well. I have a lower temp Thermostat, 160 degrees, to keep the engine running cooler and have no problem with heat.
Old 12-31-2004, 02:49 AM
buffman buffman is offline
Yeap a clogged heater core sounds like the problem to me. A different temp t-stat will have no effect on the heating of the CC. Now if you install a standard SBC T-stat into an LT1 that's a different story. LT1 t-stats are two way while SBC are one way. There's a diff.
And if you have coolant coming out of the back of the engine check the coolant transfer tube at the back of the heads for leaks..
Matt
FS: 94 Buick Roadmaster Estate Wagon (Ontario) goser Cars/Parts for Sale/Exchange 0 01-23-2007 05:58 PM
92 roadmaster estate wagon tomogchi Roadmaster 0 06-16-2006 11:41 PM
1993 Buick Roadmaster Estate wagon George Hall Roadmaster 1 08-20-2005 12:05 AM
1993 Buick Roadmaster Estate wagon George Hall Roadmaster 0 07-22-2005 11:47 PM
94 Buick Roadmaster Estate Wagon Roadmasher General Discussion 3 05-07-2004 03:47 PM
