Old 01-27-2004, 08:52 PM
h22lude h22lude is offline
Angry engine runs funny b/c alarm? help
I have a clifford intell 900 alarm system. It screwed up real bad and i couldnt even start my car because of the alarm. So i bypassed the wires so that now i cant start the car but i think the alarms hooked up some where still, because my lights will flash and my car starts idleing really high then will stop. It will go up to 2thousand somthing rpm then go to normal and then go up again. Sounds like a muscle car with a big cam. Im worried and i dont have the money to take it to a alarm guy. Can any one give me any tips or sites that can teach me how to completely dissarm the alarm disconnect? Thanks
Old 01-28-2004, 05:27 PM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Re: engine runs funny b/c alarm? help
GOTO www.directed.com and find the "guides" section then find your alarm. You can then download your install guide and it will show you what you need to know.
Old 01-30-2004, 03:22 AM
60hz163.5db's Avatar
60hz163.5db 60hz163.5db is offline
if you have an intellistart which is the clifford remote start module the tach wire may be grounding out. If you do have a remote start with this alarm system Look in your underdash and find the smaller black box labeled you guessed it intellistart. It should be connected to the alarm brain by way of thick wires with a plug inbetween the two black boxes disconnect this also disconnect the tach wire from the underhood. It should be hard to find just look at your firewall where they ran the wires through and trace them to the distributor , the fuel injectors , or a small blue plug that has two wires on it. Sorry this is a bit garbled but it is 4:20am... also take poncho's advice and get the install guide...
"Working in car audio has it's advantages, but it also shows you how much money ppl have to waste."
Old 01-30-2004, 08:32 PM
thanks, i went to the site im going to down load that guide.
HELP! 98 Jetta-Fan keeps running after engine is off Sunshine17 '97 - '03 3 01-17-2010 12:47 PM
HELP cars running funny kmcintyre87 Grand AM 2 12-07-2007 10:52 AM
Car Idles And Runs Funny!!!!please Help!!!! 94blackZ28 Camaro Discussions 2 05-08-2006 09:44 AM
My Bonnie running funny bigboyisme Bonneville 10 11-16-2004 09:10 PM
Help! My car is running funny! katschmitty Off-Topic 1 03-23-2004 07:21 PM
