Go Back   Automotive Forums Car Chat > Nissan > Almera | Sunny | Pulsar | Bluebird | Tiida | Versa | NX | Avenir | Tino | Stanza
Old 01-27-2004, 07:57 PM
ollee ollee is offline
Engine Temp problem
I just got a 88 pulsar with 1.8 engine. The engine temp will not rise unless I stick in traffic. Is it normal in this car? Because I have testdrived
two other pulsar, they seem to have the same problem.
Old 01-28-2004, 02:46 PM
Motard Motard is offline
Sounds like the thermostat is stuck, try fitting a new one.
Now working on:
HF Integrale
Completed:
Nissan 350z
WRX STi
Old 03-16-2004, 11:34 PM
lookno&go lookno&go is offline
Re: Engine Temp problem
You have an air pocket. there is a release valve, like a bleeder valve for your coolant system.this will let any air out.... The short cut to this is to drain your system. Jack the front of your car 4-5 inches off the wheel (ground) height when you refill. this should solve your problem.
Old 06-05-2004, 06:38 PM
jc58nc jc58nc is offline
When it gets hot is the thermo fan comming on?
It's controled by a temp sender at the back of the thermostat housing which signals to the ECU to turn on the themo fan.
Old 07-01-2004, 08:01 PM
WRCrules WRCrules is offline
I've got a 1993 Pulsar M1 and sort of have the same prob. Could having your thermostat stuck open result in the engine running rich?
Old 07-01-2004, 08:08 PM
Yes if the engine does not get to normal temp the ECU runs in rich mode until it does.
Old 07-01-2004, 08:19 PM
Re: Re: Engine Temp problem
Thanks for your reply. So when it's up to temp it should no longer run rich? But if it still does is it more likey to be a problem with the carb?
By up to temp on my car i mean just below half way on the temp dail. Is this where it should be on my Pulsar? Anyone else out there with the same engine - when driving on the motorway with it being cold outside (say below 10 degree's C) and doing 100km/h the whole time where does your temp sit?
Old 07-01-2004, 10:28 PM
Re: Re: Re: Engine Temp problem
Yes just below the half way mark and your heater should "belt out" lots of warm air! If not change the thermostat. Is your Pulsar a multi point fuel injected a throttle body fuel injected or carb model?
Old 07-01-2004, 11:30 PM
Re: Re: Re: Re: Engine Temp problem
It's the carb model. The heater puts out looks of hot air when on. How does that relate to the thermostat? Cheers.
Old 07-02-2004, 12:35 AM
Re: Re: Re: Re: Re: Engine Temp problem
Usualy means the themostat is working OK the temp gauge may have a problem and the carb may need a overhaul to check fuel float level.
1998 ranger engine temp problem shrdlu Ranger | Courier 4 07-07-2006 07:17 PM
engine temp problem CavLCD128 Cavalier Problem Diagnosis 2 03-25-2006 12:47 AM
engine temp problem? CavLCD128 Cavalier 2 03-20-2006 12:56 AM
Strange engine temp problem Godxzilla Accord/TSX/Accord Hybrid 8 03-15-2005 09:19 AM
86 Jetta engine temp problem pandher '83 - '90 3 08-20-2004 09:37 AM
