Read end gears: 3.73 vs 4.10
I have a 96 Mustang GT 5 speed, it is my daily driver car. I'm not looking to turn this thing into a race car or anything I'm just looking to get a little bit more kick out of my car. I also want to keep my mpg as high as possible. Which gears do you guys think is better?
Auto 4.10
5 Speed 3.73
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper. |
I agree with skyline. As a matter of fact if gas mileage is an issue I wouldn't even consider 4.10s
Maybe 3.73 or 3.55
Ported Cobra Intake, Ported & polished Windsor Jr heads, K&N, Vortech s-trim, 90mm Lightining mass air meter, 70mm throttlebody,1.7 roller rockers, BBK Long tube headers, offroad H-pipe, Crane cam, main cap girdle, 40 series flowmaster, 3.73 gears, MSD ignition, CGS subframes, A9L PIH kit, SCT custom burned chip, 42lb injectors, 190lph fuel pump, T rex and fuel pressure regulator, AFCO racing radiator (If it doesn't scare the Hell out of you it isn't fast enough) |
Re: Read end gears: 3.73 vs 4.10
4.10 for racing. 3.73 for street.
3.73s i think would be best
I live in Arizona, anybody got any idea where I can get gears installed and how much it would cost?
most private repair shops will take the job, otherwise your local performance shop would definitely do it.
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears. |
4.10s for a 2v. Especially a first gen.
Re: Re: Read end gears: 3.73 vs 4.10
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex -1999 Ford F150 |
imo, if gas was really a concern, he'd stick with the 3.08 factory gears.
how about 3.90's splitting the difference. If I'm gonna drop 400 or so I would do the 4.10 so I wouldn't be dissappointed after awhile.
I have 3.73's in my 5speed fox body, and I feel that it makes each gear too short. Although 3.55's would only lower my highway cruising by a few hundred rpms, I'd choose them over 3.73 just because the gears are so short.
I drove a 4.10 equipped 5speed foxbody, and man.. I shifted 3 times and was only going like 25 mph. haha
when in doubt, throttle. |
Dude get 4.10s!
some guys i knew had 4.10s in their stangs and it was perfect. 3.73s are ok but youd be regretting not getting the 4.10s. I for one am getting the 4.30s installed and awaiting a big grin on my face after the install
Give this place a try, You wont regret it!
Re: Re: Re: Read end gears: 3.73 vs 4.10
