Old 01-27-2004, 09:54 AM
sipunk sipunk is offline
Send a message via AIM to sipunk
B16A Oil Leak
Hi, I was just wondering if any of you would know the source of my oil leak. Ok, well this has been going on for a little bit now. It seems that oil is leaking out of my valve cover, the biggest oil spots I see are from the oil cap (which I probably just need a new one) and from the side of the valve cover, near the distributor. I thought that it might be the cam seal, but I don't see any oil leakage from there...so I was thinking it may just be a bad valve cover gasket and it just needs to be replaced. Then I saw that there was some oil that looked like it was come from the spark plugs...not sure what to make of this. Any input would be appreciated. Thanks.
Old 01-27-2004, 04:29 PM
BullShifter's Avatar
Re: B16A Oil Leak
It could need cam seals, distrib. o-ring, valve cover gasket, spark plug tube seals, & grommets. Hard to say without seeing it.
Old 01-28-2004, 12:23 AM
HondaSolutions HondaSolutions is offline
Sounds like you need new rings to me....
Honda Solutions
Performance For The Street
Oil Pressure 130 Pounds Smith1000 Park Avenue 10 04-18-2011 08:39 PM
