Old 01-27-2004, 09:46 AM
dttursi dttursi is offline
1005 Chevy Blazer
Having fuse problems with my Blazer (95). the fuse that controls inside lights and horn constantly shorts out. Any ideas? The fuse blows as soon as you put it in. Thanks
Old 11-05-2004, 08:31 PM
chosen1theatres chosen1theatres is offline
CRTSY Fuse
Have you fixed the problem? I have had the same issue.
Alfredo
Old 12-18-2004, 10:50 AM
Gumby85537 Gumby85537 is offline
Re: 1005 Chevy Blazer
Same problem fellas I would really rather fix it my self than spend a lot of money for a shop to do it. How much do you think it ould cost also what can be done to fix it yourself.
Old 10-27-2005, 03:20 PM
BLAZERBOY69 BLAZERBOY69 is offline
Check Your Light Switch(es). They Probably Need Replacing. If Not That Then Check Your Wiring In The Back Of Your Fuse Box Housing.
I'm Not Sure On This, But If The 95 Has An Under Hood Fuse Area, Check Those Fuses As Well
Old 10-07-2006, 05:44 PM
Lith1um Lith1um is offline
I just bought a 95 4dr blazer with this same issue.
Did any of you end up fixing the problem?
Im know the horn and interiorlights are on the circuit. I think the rear glass release might be on the same circuit too.
I'd really like to fix this.
