Old 01-27-2004, 07:59 AM
s10frameoff1993 s10frameoff1993 is offline
Send a message via AIM to s10frameoff1993
Diagnostic Code Error
1993 S-10 pickup
2.8L V-6
5 speed
When the engine is running, sometimes the SES light comes on and is giving me ERROR CODE 12. Chilton's says something about ignition pulse references to the ECM. Can anyone explain a CODE 12 to me? What does it mean? What do I do to get rid of it? Sometimes, when the engine is running, the SES light does not come on. Any ideas on what is wrong? And how to fix it?
Thanks.
~CS4LIFE~
www.csautoclub.com
Frame off on a 93 S-10 Pickup
Bagged & Layin' Frame
Chassis Is Molded And Painted
Suspension in ENTIRELY Chromed
Engine is Painted & Chromed
Polished Fuel Cell & Braided Lines
Stainless Steel Braided Brake Lines
"The more chrome the better"
Old 01-27-2004, 10:54 AM
quaddriver quaddriver is offline
Send a message via AIM to quaddriver Send a message via MSN to quaddriver Send a message via Yahoo to quaddriver
Re: Diagnostic Code Error
Originally Posted by s10frameoff1993
1993 S-10 pickup
2.8L V-6
5 speed
Thanks.
Code 12 just means the ECM is working properly, it means the key is on but there is no tach signal, which means you probly turned the key on with the ALDL diag port grounded and are counting the flashouts.
Keep counting.
1-2 will be presented 3 times as thus:
flash, pause, flash, flash, long pause repeat 2 more times.
THEN the true DTC(s) will be displayed, a '23' for example will be flash, flash, pause, flash, flash, flash, long pause, repeat 2 more times for each DTC
Then the ECM will finish up with 3 more '12' sequences.
'code readers' that simply contain an LED are a ripoff, they are a plastic housing with an A-B jumper wire and an LED between the SES port and ground - .50 cents of parts for $25
An actual code reader, like the autoxray is avail for about $250 for GM OBD1, or $350 for OBD2 and big 3 OBD1
You can get the much better Actron CP9110 for under $200 new, and the GM OBD1 catridge for about another $80, or go on ebay and score the whole lot for less (I got a cp9110, OBD2 generic, GM, ford and chry OBD1 cartridges for like $160 COMBINED off of ebay a few years back.)
If you have a big wallet, I recommend the $9000 Snapon Modis. IT does everything including brakes and includes step guide troubleshooting.
Old 01-28-2004, 10:39 PM
TopDogg TopDogg is offline
You can go to auto zone now and they read it for free.
