Old 01-27-2004, 08:29 AM
mistyggnt mistyggnt is offline
1998 Tauras
Hope someone can help.
My interior lights stay on. It tells me one of my doors are still open and they are all closed. Can anyone help me and tell me what this could be and how I can fix it.
Old 01-27-2004, 12:57 PM
prozak76 prozak76 is offline
Had this problem with my 97. Get a can of WD-40 and spray it in the door latch. Ford integrated the "door ajar" warning with the latch. This is not a permanent fix, but it will last for a while, and it beats paying a lot of money to replace the latch. All it is, is the latch is all gummed up. It also seems to happen with the hazard switch also.
Hope that helps you out!
Old 02-12-2004, 10:40 PM
87fox 87fox is offline
Exclamation Door switch
Your door switch is bad. Most common is the drivers door. It is a 10 dollar part and you don't even have to pull the panel off all the way if your good. FIY it is located under the latch and has a pin type switch that can be lubricated for the short fix, but the lubrication can destroy the circuit resulting in either no lights or lights all the time again.
good luck.
1998 Crown Vic Hesitats after wash fatcat0915 Crown Victoria 5 11-11-2009 04:58 PM
1998 lincoln continental electric problems linconman Continental 0 09-06-2009 12:43 PM
1998 mitsubishi eclipse rs flywheel question E. Frank Engine, Transmission and Drivetrain 4 08-22-2009 12:38 PM
1998 Passat Electrical Issues mns247365 '97+ 2 05-22-2009 01:36 PM
1998 Toyota Starlet Sportif (white) sjtilley Classifieds 0 04-13-2009 12:13 PM
