Go Back   Automotive Forums Car Chat > Honda > Integra
Old 01-27-2004, 12:33 AM
rginter rginter is offline
93 Integra GS-R idle problem
IMy 93 GS-R won't idle at a steady speed. It keeps jumping up and then dropping off. It jumps up and down all the time. Other than that it runs fine. Anyone have a clue what could be happening?
Old 01-27-2004, 01:32 AM
integralover's Avatar
integralover integralover is offline
i had a problem very similar to that with my 93 ls. when i would be at a stop light, my idle would jump up and down until i started moving. for some reason, and im not sure why, the screw on my throttle body for my idle adjust came loose? i played with that for a bit and my idle went back to normal. try that and see if it works.
93 teg LS
B20B
ACT Performance Flywheel
AEM CAI
DC Sports Stainless Steel Header
G4 High Flow Cat
GReddy MX Cat Back Exhaust
Skunk2 Racing Chip
Lots of interior goodies
Old 01-27-2004, 02:09 AM
Re: 93 Integra GS-R idle problem
I will check that out. Thanks
Old 01-28-2004, 12:13 PM
got v-tec?'s Avatar
got v-tec? got v-tec? is offline
i had same problem it wasnt the throttle cable it was the screw on the side of the throttlebody i had to take it off to reach it.
civ eg hb/b18c1
PT61 .68ar p-trim
Full-race pro street manifold
Neptune EMS
412whp@10psi 11.62@118
633whp@28psi 10.45@135
Old 01-28-2004, 07:18 PM
js94Integra js94Integra is offline
Send a message via AIM to js94Integra
My 94 Integra had the same exact problem. I fould out that the sensor on the side of the throttle body was going bad. Mine did that crap for about 8,000 miles before it wen't. When that sensor goes bad, your engine will shut off when you take it out of gear at a light or sit in nutral. unfortunatly you can't just replace the sensor, you have to get a whole new throttle body.
Old 03-11-2004, 11:31 PM
It turns out that the thermo idle valve was bad.
1995 SL Idle Problem peliknhed LS/LW 1 07-07-2009 08:30 PM
2001 Dodge Grand Caravan ES idle problem Rookie Tech Caravan | Voyager 3 07-03-2009 12:27 PM
Integra GS-R Idling problems HELPP JimmyJamz Let's get Technical! 1 05-03-2004 03:49 PM
