Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 01-26-2004, 11:08 PM
jahad jahad is offline
Send a message via ICQ to jahad Send a message via AIM to jahad Send a message via Yahoo to jahad
car acting odd
i have a 98 sunfire with the 2.2L and it is acting up. it will be fine and then all of a sudden it feels like it doesnt want to go and all kinds of black smoke comes out... i am hoping someone has had this problem before and can offer some advice on what it might be... thank you
Old 01-30-2004, 12:53 PM
Igovert500's Avatar
blue + red light magnet
Re: car acting odd
black smoke is coming out of what, under the hood, the exhaust? be more specific so we can help diagnose the problem. And what do you mean it does not want to go? Does it stop all together, or hesistate, or not go full throttle?
Old 02-01-2004, 02:58 AM
black smoke from the tailpipe, engine very shakey at idle, if i am at a dead stop i have to floor the gas pedal to go like 15 mph, also the ets light on the dash will not turn off
Old 02-02-2004, 09:54 AM
Igovert500's Avatar
Re: car acting odd
It might be alot of things, if it is blueish smoke, it might be your piston rings. Get your engine checked out.
Old 02-05-2004, 11:29 PM
Re: car acting odd
thanks for your help.... is there anyone else that can have an opinion on what might cause this problem
Old 02-11-2004, 02:20 PM
hotrodamd hotrodamd is offline
black smoke
I seen on the last post you remarked that the ETS ligt comes on, this could mean a lot or nothing at all, first thing i suggest is Make sure the gas cap is in fact tight as the ETS light will come on if not also change spark plugs just because they need replaced often anyway and theyre 5 or 6 bucks for the set(and could cause black smoke due to weak fire/unburnt fuel) next thing you may want to try is resetting computer by unhooking NEGATIVE battery cable for 15 to 30 minutes, then if light still comes on i would suggest letting a garage run a diagnostics test as it could be a map sensor, a fuel pressure regulator, a mass air flow sensor ETC.. hope this helps a little.
Drive fast or be last........
Old 11-03-2004, 09:40 PM
cchappy cchappy is offline
2 words .......02 sensor
Old 11-04-2004, 10:11 PM
Igovert500's Avatar
Re: car acting odd
You are correct...but being that he hasn't posted since Febuary I'm assuming he has since figured this out. Welcome to AF, but please don't bring old threads back to life.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Dash Warning Lights Acting Odd jstanleyfla Envoy 5 08-27-2008 04:02 PM
Brakes Acting Oddly PeteA216 Caprice 5 06-06-2007 11:33 AM
Electricals acting odd zephram22 Aurora 1 11-14-2005 02:28 PM
96 Pontiac Acting Odd FadedAsrai Cavalier Problem Diagnosis 1 09-22-2005 09:19 AM
Truck surging, Tach fluctuating, transmission acting odd tgyr5 C/K 4 09-02-2004 08:41 PM
