Old 01-26-2004, 10:19 PM
dagoEF's Avatar
dagoEF dagoEF is offline
Unhappy help! vtec soleniod gasket
Does anyone know the part # or which make/model car I can get an upper vtec solenoid gasket that will fit into a 1st gen b16a? Mine is leaking and I can only find the one from the block to the assy. ..I need the one between the assy and the little cap thing. Thanks
Old 01-27-2004, 12:44 AM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
Re: help! vtec soleniod gasket
get one for the b17a engine. its the 92-93 integra GSR. i had the same problem
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 01-27-2004, 09:02 AM
dagoEF's Avatar
Thanks, I'll go to Acura today after work
Old 01-28-2004, 11:29 AM
dagoEF's Avatar
That one isn't like the one I took out, but I managed to make it work. I have pictures of them both but for some reason it says that I can't post attachments
Old 01-28-2004, 07:33 PM
kris's Avatar
kris kris is offline
Off playing with fire.
94/95 Del Slo Si works
Old 01-29-2004, 10:24 AM
dagoEF's Avatar
Here we go I got the pic..The upper one in the pic is from what I've seen from the dealer is for 94 del sol b16, 90-94 gsr b18 or b17....the lower one is the one that was leaking that I took out from my 1st gen jdm b16. I got the new one to fit, but I'm worried it might start leaking again. I can't find the matching one anywhere. Is this just the way it looks new? Me so confused
