Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 01-26-2004, 09:49 PM
63c10sb 63c10sb is offline
Send a message via AIM to 63c10sb Send a message via Yahoo to 63c10sb
Question Coolant Leak
I am losing coolant off the back side of the engine, I have read some where that it is the intake manifold. I cant really see where it is coming from. any info would be great, 1998 Sierra 1500, 5.7 ltr
Thanks in advance
Old 01-26-2004, 10:16 PM
pistolpete76 pistolpete76 is offline
Re: Coolant Leak
i know we dont have the same car but i have the same problem i finally just found tonight that it is coming out from the back of the intake manifold, now i just need to work out how hard it is to get off etc, sounds like you have the same problem, it is hard to see up there, took me several times
Old 01-27-2004, 11:25 AM
70camaro 70camaro is offline
Re: Coolant Leak
Yes, this is a common problem with these trucks, my 97 leaks too. The problem is the lower intake gasket. Because of the torque applied at the factory, many have cracked and now leak. The fix is to replace the gasket, and torque down in a series of increasing increments. I'm not sure what the spec's are, but the dealer could tell you. If you decide to do it, let me know how it goes.
