Go Back   Automotive Forums Car Chat > Nissan > Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail
Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail Nissans greatest 4WDs and SUVs
Old 12-27-2001, 05:29 PM
Schludwiller's Avatar
Schludwiller Schludwiller is offline
XTerra Guy
SR Front Skid Mod
Here's a mod I'm trying on my front skid plate from Skid Row. While at Moab I bent back or ground down the 3 lower screws and decided to try and create some protection in front of them. I don't know if this will be the perfect solution, but I thought I would post it. I might grind down the sharp rear edge a bit to minimize catching on it when in reverse, but for the most part I'm going forward when I catch the bolts.
Xterra4x4.com and the Xterra Offroad Webring
Old 12-27-2001, 05:38 PM
ned946 ned946 is offline
Thinkin out loud here...
Is there such a thing as a carriage type bolt head (rounded and low profile) with an allen wrench center?
Old 12-27-2001, 07:48 PM
rrdstarr's Avatar
rrdstarr rrdstarr is offline
Schlud, That is what I had in mind also. Mine will add a bit of a horseshoe effect to it.
We don't give a damn how loud your stereo is!
Did you read your owners manual yet?
V.P. of PNWX
Old 12-27-2001, 10:48 PM
XTerra Guy
The horseshoe or anything that would go across the bend would have cost me more $$$. It's the straight on hits that took out my bolts, but I'll look forward to seeing your version.
Old 12-28-2001, 12:35 AM
Xlax's Avatar
Xlax Xlax is offline
There is, I too think that would be the best solution. I assume it is the 2 front bolts you were catching?....
C
Old 12-28-2001, 11:19 AM
XTerra Guy
C
Yes, but don't forget the locking washer, and a larger washer that go underneath the bolt head. That gives you a flat edge again that can be hit and bent back. Also if the allen-hole gets closed by damage you'll have an even harder time getting the bolt off.
Xlax it's the lower 3 bolts that get hit. The front 2 are up high.
Old 12-28-2001, 12:29 PM
rrdstarr's Avatar
Schlud? How much did it cost to get those three pieces welded on? I want to know if my welder is charging a fair price.
V.P. of PNWX
Old 12-28-2001, 12:57 PM
XTerra Guy
$40.
Old 12-28-2001, 01:02 PM
rrdstarr's Avatar
Thanks Dude!
V.P. of PNWX
Old 07-20-2002, 01:09 PM
cmxterra cmxterra is offline
Any worries about getting hung up on those lips if you were to be pulled from behind?
These things float... right??
Old 07-20-2002, 05:41 PM
xoc's Avatar
xoc xoc is offline
Yes, look for a Button Head Cap Screw. They may be hard to find in large sizes though.
Regards,
Ian
Old 07-21-2002, 02:25 AM
XTerra Guy
Seems like a minor chance. It's hard to tell from the un-installed photo, but they hang down just enough to protect the bolts. Most of my bolt damage has been driving under speed, not being pulled slowly across an obstacle.
Old 07-21-2002, 07:04 AM
Toy Man Toy Man is offline
AF Premium User
Button head screws
I tried that. Hard to remove when they get 'smeared'.
(I used a Dremel cut-off wheel to create a screwdriver slot.)
Toy Man
2007 FIT Unstable after Skid couchpotato General Discussion 1 08-02-2009 10:59 PM
front end mods for 96 civic alphalanos Exterior | bodykits | Lighting 1 08-27-2004 05:01 PM
GT P11 Front bumper mod - done nismo_gt Cosmetics 34 01-22-2002 01:18 PM
Factory front skid rrdstarr Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 3 11-13-2001 01:12 PM
Skid Row Front Skid Plate Mod rhombus Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 18 11-10-2001 06:24 PM
