Old 01-26-2004, 04:17 PM
fiercecivic's Avatar
fiercecivic fiercecivic is offline
Send a message via AIM to fiercecivic Send a message via MSN to fiercecivic
heater not working right??
Hey i dunno if this is they way civic are in the winter but my cars not heating up enough to make me shut it off for a bit. I have the car running full blast on pure heat and its only making it comfortable enough to drive. Even on long trips its not warming up as much as i think it should be Ive heard of people sticking carboard in front of their rads and stuff. Does anyone have a take on what could be the problem??
Old 01-26-2004, 04:36 PM
Phact's Avatar
Phact Phact is offline
Send a message via AIM to Phact
Re: heater not working right??
DONT WAIT!!!! Check your blower motor and all fuses!!! i say fuses first but me and my girlfriend were driving her accord all winter up until a few days ago when i started driving mine again, but that same thing was happening before winter, and during winter, guess what happend, blower motor went out, we still havnt replaced it and have been driving in Seriously low temperatures with no heating system. This cause my girlfriend to get a case of hyothermia, WE'VE learned, take care of it right away.
My WebSite: PhactMusic.com GRAND OPENING!
Other Ride: 91 Honda Civic Hatch DX (Currently not running.)
It just had to dry dawg - DarkImportGrey
Old 01-26-2004, 04:40 PM
wheres the blower motor?
Old 01-26-2004, 04:48 PM
i_a_n112784 i_a_n112784 is offline
Send a message via AIM to i_a_n112784
Take out your glove box to get easier access, and the blower is the thing on the right (looking at the hole where your glovebox used to be), and the motor is at the center of the bottom, and it is just 3 or 4 bolts, and it drops out the bottom.
Also, check your thermostat, it may be stuck open, causing the car to not heat up as much as it should. Personally, I suspect the thermostat, not the blower motor judging by the symptoms that you have described.
Old 01-26-2004, 04:56 PM
haha i know it sounds stupid but where the thermostat on the civics??
Old 01-26-2004, 05:30 PM
Follow the upper radiator hose twords the engine, and the thermostat is in that housing. it's just a few bolts (2 or 3). Just take off the the front of the housing, don't take off the assembly from the head. Thermostats are relatively cheap too, just make sure you get a gasket with it.
Old 01-26-2004, 05:48 PM
quickquarter quickquarter is offline
or your air/mix cable might be out of adjustment
Old 01-26-2004, 06:37 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
Its actually the lower radiator hose that connects to the thermostat.
Its held on by two bolts (plus one for the wiring harness) But if you do replace it make sure you replace the gasket too.
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 01-26-2004, 08:39 PM
Skeme1's Avatar
Skeme1 Skeme1 is offline
having very similar problems too. the blower motor stopped working.
heres a link on how to access the blower motor
http://www.binghamtonlife.com/manual...s/91-21-10.jpg
1990 DX D16Z6
Old 01-26-2004, 08:50 PM
Holy who said to undo the top hose!!! As soon as i undid it it blew all over the place! F*ck! Anyways who said changing the thermostat is easy? Its so hard to get at. Anyways thats what the problem was, the old one was full of junk and was hard to move.25 bucks later and no feeling in both hands. its replaced. I also threw sum cardbord in front of the rad to make sure she heats up enough
Old 01-26-2004, 10:08 PM
Hilikus Funkin's Avatar
Hilikus Funkin Hilikus Funkin is offline
Send a message via AIM to Hilikus Funkin
Hey as long as your car is blowing air into your car your blower motor is fine. Is the engine warming up? If thats what youre talking about then get a new thermostat. But if the actual heater isnt working you probably need a new heater core.
1991 Honda Civic DX Sedan
Old 01-26-2004, 10:34 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
does it actually work to put cardboard infront of ur rad?? i'm thinkin i need a new thermostat too cuz i need more heat but i was thinkin if i block the rad that will help, my buddy said it did for his diesel golf.... then again thats diesel
Old 01-27-2004, 07:30 AM
yeh cardboard helped, id reccomend it, jest member to take it out in the spring
Old 01-27-2004, 09:18 AM
1PhatCX's Avatar
aight man, thats coo, i'm gonna do that today when i goto the wreckers for my damn crossmember!
