Go Back   Automotive Forums Car Chat > Buick > Century
Old 01-26-2004, 04:01 PM
rrs191 rrs191 is offline
Dash Lights/Tail Lights dead
HELP!!
I have a 1990 Buick Century. The dash lights and tail lights went the other day. I don't find a dash/tail lamp fuse in the fuse box (in glove box). I've checked all the fuses in there and they all look good. I pulled the one marked cig/horn while the car was running and the car died. But the horn still worked. Brake lights and blinkers work. Is the dash/tail lamp fuse someplace else? Directions (owners manual) make no note of it. Or do I have a short?
Old 01-26-2004, 08:12 PM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
Re: Dash Lights/Tail Lights dead
Have you in the past year replaced one of your tail lights?
If you have done so remove your tail light assembly and look real close around where the studs stick out for pinched and bare wires. I have fixed many with shorted wires there.
Shop Foreman Buick Pontiac and GMC dealership
ASE Master Tech
ASE Advanced L1
GM Master tech
Licensed Aviation mechanic
Old 01-27-2004, 04:41 AM
Thanks, I can't say. I got the car this past summer. One lense is broken (hole in it). I'll check.
Old 01-28-2004, 06:21 PM
FWIW,
Chceked the wires, they were fine. Sent it to the shop. The switch was bad.
Old 01-30-2004, 12:25 AM
runningmole runningmole is offline
Send a message via AIM to runningmole
Yup, bad switch. Same symptoms on my car, so I checked out the switch. Part of it had melted
1993 Mustang GT
Blue/Titanium 2tone, 5spd, 3.55s, JBA ceramic shorties, catted H-pipe, dumped Magnaflows, MSD goodies, FMS alum rad, Pro50, balanced/blueprinted forged 327 stroker (8.2 compression), AFR 185s, Performer RPM, 70mm TB, FTI custom cam, SFC, In-floor Subframes, Maximum Motorsports Torque Arm and Panhard Bar, H&R Springs, Bilsteins, MM CC plates, 5 Lug Conversion w/ Silver Bullitts. Full accessories including smog legal. 310rwhp 351rwtq Dyno Dynamics Dyno. Soon to be supercharged
Old 02-14-2004, 12:21 PM
Wolfjr Wolfjr is offline
How much did it cost to get that switch replaced?
