Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora
Old 01-26-2004, 11:39 AM
bradjetta bradjetta is offline
Angry slow accell./ stall when engine warm
Hi,
I have a '95 Jette III GL w/ 99k mi. I did some tune-up on it this weekend, and replaced the dist. cap / rotor and air filter (I didn't have time to do plugs and cables. While I was working on it, I stupidly tore the breather tube assy., and replaced that. Now, while the engine's cold, it runs fine. After the engine gets up to operating temp, the acceleration is VERY poor, and it will easily stall out if I push on the gas too hard, regardless of the gear. It may not be related, but the engine has been sputtering just slightly lately (past month or so) when it's first started. Any ideas??? Can I get the computer diagnostic myself anywhere instead of taking it to the dealer?
Thanks in advance,
Brad
Old 01-28-2004, 11:19 PM
boschmann boschmann is offline
Re: slow accell./ stall when engine warm
Ignition coil failure is a classic on your car. Try spraying the coil with water and see if it starts arcing. Otherwise, see if it has any check engine codes.
02 Grand Am Hard Start when engine warm. ajbtrugreen Grand AM 3 08-01-2010 01:06 PM
S-10 Blazer stalls when engine is hot christian1218 Problem Diagnosis 25 10-19-2009 12:23 PM
Stalls when engine warmed? bogart219 Cutlass Series 4 06-29-2007 04:53 AM
92 S10 Blazer stalls when engine is warm bodace40s Problem Diagnosis 5 03-22-2007 05:41 AM
Stalling when starting warm engine Clubguy Camry/Camry Hybrid/Vista 9 08-24-2004 10:20 AM
