Old 01-26-2004, 12:40 AM
jonjonwells jonjonwells is offline
Send a message via AIM to jonjonwells Send a message via MSN to jonjonwells
Angry ABS Sensitivity
Can anyone tell me if there is a way to adjust the sensitivity of ABS system. I have a 2001 LS. The system releases the brakes WAY too early. Has almost got me into a few wrecks. I have currently disabled the system but would like to get it to work. Thanks
Old 01-26-2004, 04:51 PM
FOX ROCKS LIXDIX FOX ROCKS LIXDIX is offline
Banned
Re: ABS Sensitivity
there is no way to adjust the sensitivity level if your happier without abs just leave it disconnected
Old 01-26-2004, 05:01 PM
Sonny01's Avatar
Sonny01 Sonny01 is offline
What exactly are your brakes doing?
Sonny
Old 04-04-2004, 03:22 PM
mesexton mesexton is offline
ABS problems
I've had the same ABS problems with my 2001 LS. Jonjonwells - how did you disable the system? I'd like to do the same thing for the time being.
Old 04-09-2004, 04:44 PM
ABS system will activate much too early. All I did to disable is to pull the fuse under the hood. You end up with both you Brake and ABS dummy lights lit, but I havn't rearended anyone.
Old 04-11-2004, 10:56 AM
jay hullett jay hullett is offline
Re: ABS Sensitivity
is problem when u slow to about 5mph u feel a brake pedal surge or drop if so usually 1 or both front speed sensors will be faulty or have rust built up between sensor and hubbearing causing a incorrect reading to ebcm which causes a abs cycle or pedal drop
Wheel Bearing & ABS Light frehleycomet Venture 13 11-23-2013 10:27 AM
98 bleeding brakes/ABS light comes on PHXAuto Intrigue 2 09-28-2009 08:51 AM
ABS brakes on an NX1600 elanap Almera | Sunny | Pulsar | Bluebird | Tiida | Versa | NX | Avenir | Tino | Stanza 0 04-07-2009 08:41 AM
91 Ciera brakes WAAAY too sensitive vbettiga Cutlass Series 2 03-07-2009 01:57 PM
2006 4.2l f-150 abs? redka88 F Series 1 02-22-2009 10:29 AM
