Old 01-25-2004, 11:01 PM
grafix719 grafix719 is offline
!!!!! Looking for strut bars !!!!!
Does anybody know of any websites that sell strut bars for front and rear. If you do, let me know. Thanks Alot....
Old 01-26-2004, 05:08 PM
Im2Fast4U Im2Fast4U is offline
When I get mine I'm getting the rear from a member on 3si named Supermac. Front will be from EK2 Development. I don't know if they are done with these yet though. Supermac has his though. Let me see if I can find you soem links....
-Jeff
1993 Dodge Stealth
yes, it has mods....
R.I.P. DAD NOVEMBER 3, 1952-NOVEMBER 25, 2002
I LOVE YOU
Old 01-27-2004, 05:35 PM
Thanks alot jeff, my cars suspension is kinda bad so I'm in need of that rear strut bar. Just hit me back when ever you get those links....
Old 01-28-2004, 10:48 AM
Igovert500's Avatar
blue + red light magnet
strut bars
I got mine off ebay, both were under 75 each. 3sxperformance.com also has alot of bars to choose from. The rear installation was pretty easy, the only hassle is that the access panels are really small and its hard to work with them. I found it much easier to remove all of the carpeting and paneling in the trunk, install the strut bar and then put everything back together, it will really save you alot of annoyance. As far as the front strut bar goes, be prepared to fiddle with it ALOT. About half the strut bars out there don't provide enough clearance over our stock batteries. Hopefully, you will get lucky and get one that clears it, if not, most people switch their batteries and get something that's smaller, or relocate the battery to the trunk. Another solution (which I took) was to remove the bracket holding the battery in place, then struggle to get the strut bar to fit. I flipped the screws in the strut bar upside-down so the heads are on the bottom and the screw is coming up through the bar with the bolts on top. After alot of wrestling I got it to fit with VERY minimal clearance. Good luck.
strut bar recommendation dpj52190 Corolla/Matrix/Voltz 1 01-09-2011 10:50 AM
Looking for a Front Upper Strut Tower Bars dd23149006401549 Achieva 1 09-17-2009 05:39 PM
Looking for a Front Upper Strut Tower Bars dd23149006401549 Grand AM 2 09-17-2009 05:31 PM
Where Can I Get A Carbon Fiber Look Front Strut Bar? toicy4ya Classifieds 3 01-25-2006 07:37 AM
Shock Absorber Nuts for Strut Bar zenith Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 2 04-09-2003 09:00 AM
