Old 01-25-2004, 09:29 PM
white GTP white GTP is offline
Angry really crappy gas mileage
Hey I know that I am not a big poster on this site but I try to help out when i can. I was hoping someone would have an answer to this question. My car has 127,000 miles and the engine is still in really good condition, however the thing sucks gas like you wouldn't belive. When i got the car last feb. i would get around 300 miles to a tank. Now all of a sudden i'm getting 150 to a tank. WTF is with that? I had it hooked up to a scan tool and it showed a lazy o2 sensor so i replaced that and this is the first time i am testing the mileage out on a full tank. I come up with 200. Still not satisfactory in my book, when my dad's 95 grand prix is getting 300 miles to a tank. Can someone please tell me if maybe there is a coolant temp sensor that might go bad and be causing really shitty mpg.
Thanks
Old 01-25-2004, 11:25 PM
bcreverend's Avatar
bcreverend bcreverend is offline
is your air filter clean? also the way you drive the car can make a difference in what kind of milage you get....
silver 99 grand prix gtp with Intense standard pcm, 3.4 intense modular pulley, oversized supercharger idler pulley, zzp underdrive water pulley, zzp overdrive alternator pulley, tps enhancer, open cone filter, thrasher shift kit, strut tower bar, eibach springs, autolite spark plugs, 180 degree t-stat, throttle body spacer, flowmaster catback w/U-bend delete, Rear O2 simulator, silvania headlights, xenon foglights, 40 cp reverse lights, and a custom 600 watt audio with cd changer.
Old 01-26-2004, 09:23 AM
Re: really crappy gas mileage
I bought a brand new K&N air filter changed the fuel filter and also changed the plugs and wires.
I live out in the country so I do drive with a heavy foot but is that enough to make the milage change that much?
Old 01-26-2004, 12:18 PM
fast98gtp's Avatar
fast98gtp fast98gtp is offline
Send a message via AIM to fast98gtp
possibly, just depends on HOW hard you drive it.. i used to drive my car hard when i got it but never got that bad of mileage. i normally get about 275 miles to a tank doing a LOT of city driving, and that's with mods. i dont know a whole lot about diagnosing fuel problems...could it possibly be fuel injectors maybe being stuck? .. just a guess
Old 01-26-2004, 01:14 PM
carnutcass's Avatar
carnutcass carnutcass is offline
This question comes up a lot on the national board. Try this: http://www.clubgp.com/newforum/tm.as...mode=1&smode=1
I know that you're car is a GTP but some of the suggestions still apply.
Old 01-26-2004, 01:17 PM
ok thanks i'll take a look at that
Old 01-29-2004, 03:18 AM
JoeJoe231455 JoeJoe231455 is offline
Re: Re: really crappy gas mileage
Have you ever had your injectors cleaned? Does the car take a little more time to start in the morning?
That may be your problem right there...
Change the pcv valve if you have not done so recently...and check your tire pressure...
All three of these things can effect mileage a good bit.
Old 01-29-2004, 03:19 AM
Re: Re: Re: really crappy gas mileage
Have you replaced your plugs and wires?
Old 01-29-2004, 05:31 PM
Yeah I have replaced the plugs and wires, I did a pretty basic tune-up when i got the car including coolant flush and stat, plus the o2 sensor now. I haven't had my injectors cleaned which gives me a thought, and haven't touched the pvc vavle. Tires are always well inflated. Cars got 127k on it so I'll try just about anything at this point. I'm also going to try taking it easy on the gas pedal and see if that helps out a good deal
Old 01-29-2004, 05:55 PM
JOEROC JOEROC is offline
Send a message via AIM to JOEROC Send a message via Yahoo to JOEROC
smell your oil on dip stick if theres gas in your oil it maybe your fuel pressure regulator seen this a few times
Old 01-29-2004, 05:59 PM
also pull the vacuum line off of the fuel pressure regulaor if theres gas in it you found your problem
an expensive one to boot get a used one for a car with that many miles
Old 01-29-2004, 07:33 PM
yeah there is a gas smell on the dipstick but i'm not even sure were the regulator is. Isn't it under the plenum? I take classes at the tech school so i'm not that illiterate i just dont know were the regulator is.
Old 01-29-2004, 11:56 PM
the regulator should be in thr rear of the plenum
you can get to the vacuum line with a long needle nose plierse
it should look like a beer keg with vacuum....HAHAH
if you cant get to that pull other vacuum lines and smell them
if thers a strong gas smell in your lines its a very good indication of the problem
also pull the boot off your throttle body and check for gas
also smell your exhaust for raw fuel smell
you ask about coolant censer maybe but it wont make it use fuel that bad and change your oil soon
Better gas mileage Stapletonb08 Cavalier 3 03-03-2011 01:02 PM
99 Grand AM GT = Crappy Gas Mileage FleshAndBlood1990 Grand AM 9 03-22-2007 09:16 AM
crappy gas mileage Budjr52 Metro 13 03-13-2006 12:08 AM
crappy gas mileage. mr_jones71 Grand Cherokee | Grand Cherokee SRT8 9 03-06-2006 05:40 PM
F-150 Crappy Gas Mileage Ferni173 F Series 6 10-28-2005 08:18 AM
