Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 01-25-2004, 08:38 PM
solarbear solarbear is offline
Unhappy '01 rodeo problems.......HELP!
Hey all.....I'm new to this forum, glad to have found it as my wifes rodeo seems to be falling apart. This has been a great vehicle for us and we keep oil changed every 3k, just seems that lately we are having problems. Any suggestions would be greatly appreciated.
1. Rear Windsheild wiper quit working and the fuse looks to be fine.
2. Eating up oil somewhere and doesn't seem to be leaking anywhere.
3. The front grill is sqeeking when going over bumps/ slow speeds, and is driving my wife crazy.
4. Check engine comes on when very low on fuel and then will go out later on.
5. Slight jerk when taking off from start.
This vehicle only has 50k on it, wish we werent having these problems already.
If anyone has any solutions to any of these problems, please help.
Thnks
Old 01-25-2004, 10:45 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: '01 rodeo problems.......HELP!
1. try a search here or at planetisuzoo.com, I know I read something about this before.
2. Oil. How much is it eating? If it is over 1qt per 1k isuzu should give you a new engine (the dealer will need to moniter it), The main things that lead to oil consumption is, a dirty PCV (12 bucks to replace), dirty EGR valve, port tube (behind the trottle body) and exhaust tube off the EGR. These can be cleaned up with about 1.5 hours of DIY work and a 1 dollar can of carb clean (safe for O2 sensors). Again search for EGR here. Last thing to do, it to run a couple of bottles of chevron techron concentrate (10bucks at target) in you gas for a couple of tanks.
3. The squeak is coming form the rubber bumpstops where the hood rests on. Find the side that is sqeaking and give is a 1/2 turn and a dab of grease on top of the rubber bump stop.
4. it the CEL light comes on with low gas it is caused by a faluty fuel sender unit in the gas tank. It is covered under your 10yr/120k warrenty. If you have a CEL the code will be saved in the ECU for 30-50 starts before it is cleared. So when it happens again take it is have the code read and have it replace.
5. Jerk, thump clunk. Search for it here. The problem is that the slip yolk in the drive shaft needs to be regreased. Some dealers cover this under warrenty other dont. I paid 50 bucks for my dealer to regrease it for me.
So for a few bucks a few of the small things you can do yourself. And a couple of other things your dealer should be able to do for free.
-Ryan
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 01-26-2004, 11:48 PM
tdupes tdupes is offline
i have the same problem with my rear wiper. It seems that every couple weeks I'll forget that it doesn't work and put it on and it will go one time then stop and won't come back on again. it seems that the sound for the washer button is coming from the glovebox. Any othewr suggestions?
Old 05-20-2004, 12:10 PM
Mark12 Mark12 is offline
Check that the wiper blade is tight. Mine worked its way loose and you have to lift the cover at the base of the wiper and tighten the nut. Good luck.
Old 05-21-2004, 05:10 PM
mospeed1 mospeed1 is offline
Send a message via AIM to mospeed1
Thnks[/quote]
i have this on my truck as well on take off a clunk noise and a jolt forward ...the stealership told me i had to have my rear brake adjusted??????????????/
02 rodeo ls
old ride 95 200sx full showcar
95 Towncar trans problems....help!!!! speeddemon_09 Town Car 4 09-20-2009 10:20 AM
97 ram 1500 sport 4x4 tranny problems HELP ME! tabes Ram Pickup | Ram SRT10 3 03-14-2009 08:56 AM
Possible '01 Rodeo Sport owner here-help? palomo93 Rodeo | Passport | MU 2 04-30-2008 03:20 PM
1996 Isuzu Rodeo Problem-Help?! RodeoSteve Rodeo | Passport | MU 4 08-14-2005 06:46 PM
PLEASE help quick !! '01 Rodeo Check engine light/$400!?!?! BrettnATL Rodeo | Passport | MU 7 01-30-2004 05:34 PM
