Old 01-25-2004, 05:59 PM
89bxci-vic 89bxci-vic is offline
Send a message via AIM to 89bxci-vic
Clogged injector, HELP!
Just changed the gas tank on my 89 dx hatch (stock) and then it started stalling while i was driving. It wouldn't completely shut off , just not respond to the throttle for a few seconds. Then i'll tap on the gas a couple of times and it would go back to normal. this keeps on happening. I gave it a complete tune up and checked the fuel pump so its not those things. I think the injectors are clogged, does anyone know how to fix them. Moneys tight, thanks to bloomberg. If anyone can help i'd appreciate it.
you almost beat me?
you never had your car!
Granny Shifting! Stressed cause your girl's on my lap! Don't worry you'll catch'em in the turns, slow cars can be fun too!
Old 01-26-2004, 11:11 AM
vesper's Avatar
vesper vesper is offline
Send a message via AIM to vesper
Re: Clogged injector, HELP!
when you put you fuel tank back up make sure you dint crimp one of the fuel lines. i replace the fuel pump and when i put the tank back up it was hitting a line. then i replace the feul filter after that
and it dint start at all.
make sure you dint do that.
also go get some fuel injector cleaner see if that helps.
help! fuel injector problem Suzannes Caravan | Voyager 9 11-07-2009 01:06 PM
clogged injector or something...Help!! ((Vibe)) 323/Protegé/Familia/Etude/Allegro 5 06-26-2008 03:14 PM
lower intake manifold gaskets and clogged injectors czechnate Alero 0 03-03-2006 07:30 PM
What size fuel injectors???? HELP ME!!! RyanU1 Camaro Discussions 0 11-04-2003 10:25 PM
CIS-E, 87 5000S, NO Fuel to Injectors, HELP BinsuJiro General Discussion 0 10-19-2003 10:38 AM
